Clarke-Tech HD Plugins
Rasprava u 'Clarke-Tech HD Plugins' pokrenuta od macro®, 8. Studeni 2011..
  1. macro®
    macro® Administrator
    20,814
    15,365
    And yet another new version, version 7.0. This time some corrections in the languagefile(s) and an new translation, French! (Thanks Demosat!) It could be that some é è á ü etc leters are still missing because of the first versions a wrong code was used and the special character got lost in translation.
    If there are persons who want to add another language feel free, in the folder locale is a .po file with the name Default.po, this file can be used to add a language. The file can be edited by any texteditor or with the program Poedit which can make a translated file (.mo) Poedit can be found
    I also forgot to thank Biki3 and Bonsai Baum for their German translations.
    The new version is attached at the end of this message.
    Here are some screens from the French version
  2. macro®
    20,814
    15,365
    The supported languages are now: English (default), Dutch, French, German, Polish and Russian.
  3. zvonko67
    zvonko67 New Member
    6. Ožujak 2011.
    7,106
    5,422
    crosat umirovljenik
    PlayStream and PlayStreamVlc for Live Streaming TV [HR][/HR]PlayStreamVlc needs a working setup of plugin Vlcplayer.
    For PlayStream - TV button will stop streaming.
    thx pdc
  4. zvonko67
    zvonko67 New Member
    6. Ožujak 2011.
    7,106
    5,422
    crosat umirovljenik
    [h=2]Boblight v0.1BETA for ET 9x00[/h]
  5. zvonko67
    zvonko67 New Member
    6. Ožujak 2011.
    7,106
    5,422
    crosat umirovljenik
    New version 9.7
    modified:
    - Improved detection / handling of media mounted on / hdd. Because mounts on / media / net sometimes long filenames have worked to detect the total volume, available size and name of the mount is not good. If the file names are too long shifts the output of df to a new rule and not the data in the wrong column so that the reporting no longer worked.
    - Added an additional check on the mkfs.ubifs Xtrend models that run on image V5
  6. beli1910
    14,314
    14,314
  8. Pazarac
    Pazarac Clan
    20. Studeni 2011.
    223
    71
    Novi Pazar
    Kicker online 2.20 (OE2.0)
    Version 2.2
    - Neu: Größe des Plugins bei HD-Skins einstellbar (Startscreen -> MENÜ -> Auswahl zwischen 2 Größen)
    - Neu: Zeit bis zum Ausblenden/Hide des Live-Tickers einstellber
    - Fix: Live-Spieltagergebnisse (nach Änderungen auf kicker Seite)
    3 članova se sviđa ovo.
  9. Pazarac
    Pazarac Clan
    20. Studeni 2011.
    223
    71
    Novi Pazar
    Notepad++ 6.2.2
    Notepad++ kennt neben allen "großen" Programmiersprachen wie
    C++, Java, XML, HTML, SQL und PHP auch jede Menge Kleinstsprachen.
  10. Pazarac
    Pazarac Clan
    20. Studeni 2011.
    223
    71
    Novi Pazar
    Webbrowser v1.5.2
    Changelog:
    fixed keyboard bug
    fixed crash with v1.5.1
    fixed Weblinks Streaming
    Change navigation menu to a pulldown menu.
    many other fixes.
  11. Pazarac
    Pazarac Clan
    20. Studeni 2011.
    223
    71
    Novi Pazar
    kino.de 0.51
    kino.de 0.51
    KINO.de (alle aktuellen Filme, Trailer und deutschlandweites Kinoprogramm) by kashmir
    Bei der Suche nach dem aktuellen Kinoprogramm kam kashmir die Idee zu dem Plugin. Kino.de hat zu allen aktuellen
    Kino-Filmen ausführliche Informationen, Trailer, Bilder und man kann auch eine Liste aller Kinos in Deutschland aufrufen,
    in denen der jeweilige Film läuft.
    Beim Start des Plugins werden 10 Webseiten mit den aktuellen Filmen abgerufen, daher kann das Laden
    der Liste ein paar Sekunden dauern.
    Bedienung:
    OK = Zu den Filminfos
    Rot = Trailer starten
    Gelb = Fotoshow
    Grün = alle Kinos, in denen der Film läuft
    Blau = Plugin aus- und wieder eingeblenden
    Bouquet = Kanalliste aufrufen
    Das Plugin ist für XD und HD Skins angepasst.
    Viel Spass mit dem Plugin!
  12. Pazarac
    Pazarac Clan
    20. Studeni 2011.
    223
    71
    Novi Pazar
    EMC V.3.6.6 beta - Enhanced Movie Center
    EMC V.3.6.6 - Enhanced Movie Center
  13. Pazarac
    Pazarac Clan
    20. Studeni 2011.
    223
    71
    Novi Pazar
    Backupsuite 11.1 (OE2.0)
    Backupsuite 11.1
    - Added support for the MK-Digital / MaxDigital / XPert XP1000
  14. macro®
    20,814
    15,365
    backupsuite_11.2
    Code:
    Changed in version 11.2compared to 11.1 - Added Turkish translation (Big thanks to SSD)
    BackupSuite for Openpli 3.0 version > 10
    Thx @Pedro_Newbie
  15. macro®
    20,814
    15,365
    backupsuite_11.3
    Code:
    Changed in version 11.3 compared to 11.2 (minor changes): - Changed the colour purple a little so it's better readable; - Changed some translations (German, Thxs Holymoly); - Added the word minutes after the time measurement (for all languages).
    Thx @Pedro_Newbie
