e2 > m3u > 2bouquet > konverter
Rasprava u 'VU + ® Addons & Tools' pokrenuta od mamba65, 7. Ožujak 2018..
  1. mamba65
    6,501
    4,317
    enigma2-plugin-extensions-e2m3u2bouquet_0.7.2_all
    whats new:
    Code:
    Make sure comments are xml safe
    Extract username and password from m3u url if they are not passed in
    Set services to stream type '1' in epg config so that the epg can be imported if
    serviceapp is overriding stream type '4097' to exteplayer3
    Minor fixes & tidy
    Option for custom stream type for TV and VOD
    Allow https & rtmp services
    Unicode fixes
    Url encoding fixes
    [plugin] Multi custom provider support
    [plugin] Config file based setup (values can be edited in an xml file instead)
    of entered using the remote
    [plugin] Provider managed update system
    [plugin] Fixed time schedule type
    [plugin] Option for custom stream type for TV and VOD
    notice:
    -all data information & configuration is now in path -- /etc/enigma2/e2m3u2bouquet/config.xml
    -open plugin & go to configuration where u shall input all data & details of your iptv chs m3u link
  2. mamba65
    6,501
    4,317
    enigma2-plugin-extensions-e2m3u2bouquet_0.7.3_all
    whats new:
    Code:
    -Fix issue with main screen showing no text on some skins
    -Add option to reset bouquets
    benes-m se sviđa ovo.
