Pozz. Kupio sam ovaj feedhorn z parabolu 1,85 i sada nisam siguran koji lnb da kupim uz njega. Ako neko ima iskustva sa ovim molio bih da mi preporučite koju kobinaciju da napravim. 1.Inverto Black Pro Flansch IDLB-SINFO1 OOPRO Single LNB 0.3dB This content is protected Geringes Phasenrauschen, DVB-S2 (HDTV) kompatibel Lowband Eingangsfrequenz: 10,7 - 11,7 GHz Ausgangsfrequenz: 650 - 1950 MHz LO Frequenz: 9,75 GHz Highband Eingangsfrequenz: 11,7 - 12,75 GHz Ausgangsfrequenz: 1100 - 2150 MHz LO Frquenz: 10,6 GHz Rauschmaß: 0,2 dB LO initiale Genauigkeit: max. + / - 1,0 MHz LO temperaturabhängige Abweichungen: max. + / - 3,0 MHz Phasenrauschen (bei 10 kHz): max. -80 dBc / Hz Wandlungsgewinn: 53 - 63 dB Brummverstärkung (über 26 MHz Bandwidth): + / - 0,75 dB Veränderungsverstärkung (über Vollband): max. + / - 4 dB Unterdrückungsfaktor: 40 dB Minute 1 dB Kompressionspunkt 0,0 dBm Minute Überkreuz-Polarisation-Isolation: 22 dB Minute Control Signal Ca (vertikale Polarisation): 11,0 - 14,0 Volt Control Signal Cb (horizontale Polarisation): 16,0 - 20,0 Volt Control Signal Cc (Band Switching): 22 + / - 4 kHz Ausgang VSWR: 2,5 : 1 In-Band Spurious: max. -60 dBm Stromverbrauch: max. 110 mA / 11 - 20 Volt Betriebstemperatur: -25 - +60°C Ausgangsimpedanz: 75 Ohm Ausgangsverbindung: F-Type 2.Inverto Single LNB 0.3db Flange Sat Flansch Kopf LNB LMB 40mm Feed 3D SKY UHD This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected This content is protected
