Flashing your AZBox HD Elite/Premium(+)/Ultra
Rasprava u 'Azbox HD Razgovor & Tutorials Sekcija' pokrenuta od zvonko67, 1. Travanj 2012..
  1. zvonko67
    zvonko67 New Member
    6. Ožujak 2011.
    7,124
    5,430
    crosat umirovljenik
    If you want to install OpenRSi firmware from you original OpenSat firmware, please follow the steps in this video
    From original firmware
    There is a video we would like to provide on how to install the OpenRSi firmware, using a first generation AZBox HD with the original OpenSat firmware.
    Please, take your time and watch the video. It is pretty much self explanatory
    <IFRAME id=yui-gen24 class=restrain title="YouTube video player" height=390 src="//www.youtube.com/embed/qhzb2NOF1Dw?wmode=opaque" frameBorder=0 width=640 aspect="1.64102564102564" origheight="390" origwidth="640"></IFRAME>
    Otherwise, follow the tutorial below.
    Be sure you have downloaded the right firmware and/or kernel from our downloadpage.
    Also, be sure that your AZBox HD receiver is connected tot the netwerk, using a LAN cable. We do not recommend Wireless connections.
    NOTE:
    In this tutorial, we will install OpenRSi, including the kernel, which you will find on our downloadpage.
    In case you have installed our kernel in an earlier stage, you do not have to install the kernel again and you can skip the "Installing the kernel" procedure.
    If you want to install OpenRSi from within the original OpenSat firmware, please take a look at the video at the top of the page.
    First step
    If you don't have Azup installed on your PC, please follow the next steps:
    Download and install Azup 2.0.4 (latest installer version).
    Download and unpack Azup 2.1.6
    Download the latest firmware and kernel for your AZBox HD, from our download page
    Flip the powerswitch at the back of you AZBox HD receiver.
    While booting, press and hold the Volume + key on your remote control, until an IP address is shown in the display.
    Start Azup 2.1.6 on your PC.
    Please, enter the IP number that was shown to you on the display of the AZBox HD receiver.
    In Advanced Options, select the "Only kernel" option ( all other options will turn grey).
    Press the GO button in the Install E2/Kernel section.
    A window will pop-up. Select the kernel file, which you have downloaded from our downloadpage and double-click on it or click on the Open button.
    Azup will now install the kernel files. When it is done, the AZBox HD will reboot.
    Installing OpenRSi firmware
    Start Azup 2.1.6.
    Please, enter the IP number that was shown to you in the display of the AZBox HD receiver.
    De-select the options "Only Kernel" and "Copy kernel" in Advanced Options.
    A pop-up window will show. Select the OpenRSi firmware file, which you have downloaded from our downloadpage and double-click on it or click on the Open button.
    Azup will now install the OpenRSi firmware. When it is done, the AZBox HD will reboot.
    After rebooting, your AZBox HD receiver will show the Enigma2 Setup Wizard.
    NOTE:
    First step
    Start Azup 2.1.6.
