Glass System Utility (GSU)
Rasprava u 'VU + ® Addons & Tools' pokrenuta od vusolo2, 28. Siječanj 2016..
  1. vusolo2
    vusolo2 Forum Friend
    15. Prosinac 2015.
    484
    138
    slovensko
  2. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - channel info: fix bitrate type detection
    - system info: fix total ram calculate
  3. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - fix devices manager
    - fix system info
    - some OE2.2 fixes
    - added new option "with net check" to activate autocheck of cifs/nfs mounts defined in nfs_cifs.cfg - work correct if device provided network share give a respond to socket on port 80 (webinterface of the device)
  4. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - system info: added next method to get HDD temperature (tryfix on some HW,SW)
    - channel info: added next method to get bitrate (tryfix on some HW,SW)
    - fix some code bugs
    - added support /fix graphics with alpha across all OE (from OE1.6 to 2.2 including latest OS)
  5. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - system info: autostop hdd after exit
    - added support CA Tandberg
    - cifs, nfs: added new option "nolock" in gsu options, used as mount option of nfs if is enabled
  6. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - fix ipk installer
  7. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - added support for Ncam
    - channel nfo: added detection of dvb-t2
    - UCM download: added Ncam 1.1 mipsel arch
  8. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - oscam info: fix oscam status
    - added option to set refresh time oscam log
    - oscam info: fix oscam readers
    - fix osd ecm info
    - added full support of FHD skins - autodetektion
    - updated all screens - autoswitch to 32bit graphics if Full HD mode is active
    - added option of "direct activation" of ECM info press red button (lowest priority and if image do not use red button as any fnc), can be enabled/disabled in UCM settings (green - direct start of UCM, red - direct start of ECM info)
    - channel info: added alternative method of tyner type detection
    - oscam info: oprava oscam status
    - pridana moznost nastavenia refresh time pre oscam log
    - oscam info: oprava oscam readers
    - oprava osd ecm info
    - pridana plna podpora pre FHD skiny - autodetekcia
    - aktualizovane vsetky screeny - autoprepnutie na 32bit grafiku ak je Full HD mod aktivny
    - pridana moznost "priamej aktivacie" ECM info stlacenim cerveneho tl. (najnizsia priorita, pokial si ho image prioritne nemapuje), povoluje/zakazuje sa v nastaveniach UCM (zelene - spusti priamo UCM, cervene spusti ECM info)
    - channel info: pridana alternativna metoda detekcie typu tunera
  9. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - system info: fix CPU using calculation
    - system info: fix displaying FHD icons
  10. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - fix oscam ymod version detection
    - added detection of modulation 16APSK, 32APSK (DVB-S/S2 only)
    - fix/corections more of screens
  11. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - added support and detection of Gcam
    - added alternative method to searching of picons
    - fix displaying version of cam/srv in download menu
  12. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    - added help with translations to CAM/SRV manager
    - edited script centers with full support for naming translations and user script descriptions
    - added another cmd options for oscam start cfg
    - updated sk, cz translations
    - added picon channel to CAM/SRV manager
    - fix UHD, FHD, HD screen for CAM/SRV manager
    - changed calculation of position of satellite from static to dynamic by tuned data from tuner - it also allows you to get info about the newly created or non-standard sat positions - used in the channel information, CAM/SRV manager
  13. vusolo2
    15. Prosinac 2015.
    484
    138
    slovensko
    GSU ver. 10.18
    - added enhanced method searching picons
    - CAM/SRV manager: fix avalaible CAIDs
    - main code and screens corrections
    - fix/enhanced detection DVB-T/T2
    - fix channel information screen
    update is available online
    Thx@shamann​
