HD Glass Skins
Rasprava u 'VU + ® Skins & Bootlogos' pokrenuta od macro®, 16. Prosinac 2010..
  1. vusolo2
    vusolo2 Forum Friend
    15. Prosinac 2015.
    462
    135
    slovensko
    - added new options in section "TUNER": Recording, Recording and live (colors)
    - added new option in section "INFOBAR": Show recording icon
    - help updated in download menu
    - updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
    - added autodetect Temp./RPM N/A and display values only not N/A state exception
    if both values are N/A display Temp. N/A, RPM N/A
    - redesigned extrascreens: 29, 88
    - fix restore config in the setup
    - added support to latest changes in DMM OE 2.2 images
    - added next method to get AC3/Dolby detektion across all OE1.6-2.2
    - added detection DVB-T2, DVB-T/T2 (if it is supported in enigma)
    - added new option: Audio type of current track
    - added detection of audio type: DD5, DD2, DTS, AAC, MPG (after restore icons
    type will be set to default type 1, so after update and autorestore you must
    download icons and previews and then set/select your prefered icons type)
    - added support for "snr db" on HW without direct support in enigma
  2. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - fix detection audio typu
    - oprava detekcie audio typu
  3. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - added detection of Ncam (after restore icons type will be set to default
    type 1, so after update and autorestore you must download icons and previews
    - piconCam updated in download
    - weather: yahoo pressure autofix if yahoo generate wrong recalculate units
    - updated and added et translation (thx zeros, Henkka) to eWea
    - fix Find a city if is selected from main menu
    - added new option: Detection Progressive/Interlaced in resolution info line
    - fix Channel number calculation
    - added new Menu type: simply PIG
    - added all config values to translations
    bica and mamba65 like this.
  4. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - updated enhanced weather translations
    - fix multiple definition screens (deb version only)
    - removed options: Autodetect HDD, Path to HDD, OLED dir, Picons/Icons path
    - added option in section HDD: HDD and added new section "OLED"
    - added options in section OTHER: Picons/Icons path, User defined path
    - big optimalisation of the main code and changed definitions of some cfg values
    so after update will be some cfg/function switched to the default value and you
    can set your prefered options after autorestore:
    Enable Enhanced Infobar
    Second picon type
    ECM line type
    Volume type
    HDD
    Enable piconCam
    Picons/Icons path
    OLED dir
    EPG selection type
    Ignore infobar timeout
    Enable control of network status
    PIG type
    - updated help sk, cz, en
    - removed section "SCREENS", items moved to section "OTHER"
    - fix Extra screen 8
    - weather: fix MSN if wind direction is not available
    - fix user info: system info, side bar
    mamba65 se sviđa ovo.
  5. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - changed User defined path to selection of dir by using Location box, if is
    Picons/Icons path used as User defined path the one will be set to default value
    and you can set your prefered options after autorestore
    - updated help sk, cz, en, lt
    - setup of the skin: added moving to last item/section if is active first item
    press Up/Ch + and moving to first item/section if is active last item press
    Down/Ch -
    - fix TP info a ECM status
    - added new option: Calculation of channel numbers - static/dynamic, section OTHERS
    static - recommended for old HW
    - added color "grey 5" at all color selection
    - added new option: Date format - in sections: INFOBAR/EXTRA INFOBAR, OTHERS,
    CHANNEL SELECTION, MENU
    - splitted section INFOBAR to sections: INFOBAR,EXTRA INFOBAR,INFOBAR/EXTRA INFOBAR
    - added new options: Date (color), Time (color), Seconds (color) in section
    EXTRA INFOBAR
    - added autodetection of possible OLED type by hw
    - fix detection of decoding type - dynamic icons
    - added autohiding of options unusable in image/hw
  6. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - updated enhanced weather translations: sk, cz, en, et, lt
    - updated pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
    - updated help translations: sk, cz, lt, ru
    - INFOBAR: removed - Simple base infobar
    - INFOBAR/EXTRA INFOBAR - removed - Date format
    - INFOBAR: added - Date format
    - INFOBAR: added - Standard Infobar type (including def. Simle base infobar)
    - EXTRA INFOBAR: added - Date format, Channel name (color), Event now (color),
    Event next (color)
    - OTHERS: added - Ignore leading 0 in time
    - INFOBAR: added - Standard Infobar type - Standard2
    - fix channel number calculation - static
    - MENU: added - menu type - with PIG2, with PIG3, with PIG4
    - updated in download menu - Menu icons big
    - fix date format parser
    - added support and detection of DVB-S2X system
    - TUNER: added - Hide tuner in standby or missing
    - added Extra Infobar 54
    - added support for DM900UHD
    - OTHERS: added Single EPG type: with PIG(+number, ch.name)2
    - OLED: added - oled type (DM900UHD, Vu+ 4k) - Classical, with ZZPicon
    - changed Location box to Dir browser for path setting of picons/icons
    - HDD: added type Auto (autodetection)
    bica se sviđa ovo.
  7. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - fix getting of HDD tmperature
    - edited: Standard Infobar2 and Extra Infobar 33, 54 and Extensions list
    - CHANNEL SELECTION: changed - New style(colored list) changed to New style2
    - added Extra Infobar 55, 56
    - help, extrascreens graphics a previews updated in download
    - OLED: added - oled type (DM900UHD, Vu+ 4k) - Classical2
    - fix USER INFO - system info
    - WEATHER: fix SSL certificate error - Yahoo provider
    - fix management of path setting of picons/icons
  8. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - OTHERS: added volume type - Percentage2, Display Extensions as Choice box
    - edited/changed texts in download menu
    - CHANNEL SELECTION: added - Display remaining time in extra EPG
    - added detection of fake ecm if is used
    - WEATHER: added - Enable use SSL unverified content
    - MENU: changed design of type List2
    - added detection et8500
    - fix detection of tuners (A,B...,A1,A2...)
    - ECM INFO: added ecm line type - CAID, SID, PCR
    - fix detection of openAtv 6.0
  9. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - fix autocenter of extra screens by enigma (all types)
    - added detection of Constant CW (after restore icons type will be set to default
    - OTHERS: added Path to configuration file of HDG
    - CHANNEL SELECTION: added options - Service name font size,Service info font
    size, Line height, Extendted description font size
    - added new option: Reset all settings of HDG
    - OTHERS: removed options - EPG selection type, font event act. and next
    - added new section: EPG SELECTION
    - EPG SELECTION: added - EPG selection type, Extendted description font size
    - ENHANCED WEATHER/WEATHER: fix displaying of colors for warm and cold
    temperature (C <-> F)
    - ENHANCED WEATHER: added - temperature unit (C, F, from /etc/ewea_city_Code.txt)
    - enhanced weather - removed change units, added Select City - it is possible to
    add unlimited numbers of cities and choose for which will be weather displayed,
    all cities are stored in /etc/ewea_city_Code.txt
  10. bica
    bica Super Moderator
    10. Rujan 2011.
    1,028
    1,658
  11. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - updated lcstrings.list
    - fix displaying title of Channel selection
    - fix extra EPG renderer
  12. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - added alternative method to detect IPTV stream
    - WEATHER: added support of SSL certificates
    - OTHER: removed - user encoding.conf (deb version only)
    - fix oscam ymod version detection
    - added detection of modulation 16APSK, 32APSK (DVB-S/S2 only)
  13. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    HD Glass 16 ver. 11.77
    - fix/corections more of screens
    - fix devices label (USB,HDD)
    - restore cfg: changed to Dir browser with option to choose any .conf file
    to restore cfg
    - SETTINGS OF HDG: changed layout, removed function of blue and yellow button,
    splitted function of green and OK button, button OK aktivates function of some
    items, press green button to save cfg only
    - fix screen History
    - changed skin of all setup screens
    - DOWNLOAD MENU: new skin and the new method of download - you can select items
    to downlad and selected items are downloaded all at once
    - HDG SETTING: added current path displaying in directory browser
    - aktualizovane: pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl,
    et, lt
    - opravy/korekcie roznych screenov
    - oprava nazvov pre zariadenia (USB,HDD)
    - obnova cfg: zmenena na prehliadac adresarov z moznostou zvolenia lubovolneho
    suboru .conf s cfg ktora je pozadovana na obnovenie
    - NASTAVENIA HDG: upraveny vzhlad, zrusena funkcia pre modre a zlte tlacitko,
    oddelena funkcia pre zelene a OK tlacitko, OK aktivuje funkcie pri niektorych
    polozkach, zelene tlacidlo sluzi len na ulozenie aktualnej cfg
    - oprava obrazovky Historia
    - zmeneny vzhlad vsetkych obrazoviek setup-u
    - PONUKA STAHOVANIA: novy vzhlad a nova metoda stahovania - mozete vybrat polozky
    na stiahnutie a vybrane polozky su stiahnute naraz
    - NASTAVENIA HDG: pridane zobrazenie aktualnej cesty v prehliadaci adresarov
    update is available online (setup and website)
    Thx@shamann
  14. vusolo2
    15. Prosinac 2015.
    462
    135
    slovensko
    - dir browser: added path autocutting in title
    - DOWNLOAD MENU: changed results layout after files download
    - fix line hight auto settings in Channel selection
    - fix ECM PID displaying (deb version)
    - WEATHER: removed option "Find a city" (in extensions, in menu), added option
    "Find a city" activated immediately press OK button
    - added Extra Infobar 57
    - fix "Find a city" Yahoo type searching
    - TP INFO: extended support of HEVC codec
    bica se sviđa ovo.
