~Modificirani & Original Skinovi Vu+ Dreambox mamba65~
Rasprava u 'VU + ® Skins & Bootlogos' pokrenuta od mamba65, 22. Veljača 2014..
Status teme:
Nisu omogućeni daljnji odgovori.
  1. mamba65
    6,484
    4,294
    Fast Full HD 1920 x 1080 Skin
    *Screens say everything what is all in Skin...*
    *For crash or improvements please a feedback*
    * Weather Settings *
    *1 Oppen you Weather Plugin plugins browser
    *2 Press menu from the keyboard
    *3 green button (Add)
    *4 write the name of the city in option (City)
    *5 Click on the yellow button (search code)
    *6 Now select your city and press green button (ok)
    *7 Press the green button (OK) again
    *8-Done Quit plugin bu Press exit button
    P.S.for member LUCEK SAT ,DONT COPY SCREENS AND SAY IS YOUR IDEA!
    profidream and vusolo2 like this.
  2. mamba65
    6,484
    4,294
    see all screens up like skin OpenATV ... only is adapted for OpenPLi
  3. mamba65
    6,484
    4,294
    *FOR >
    < Image*
    *Screens say everything what is all in Skin ...New Menus and new look...*
    vusolo2 se sviđa ovo.
  4. mamba65
    6,484
    4,294
    Posljednje uređivanje: 13. Studeni 2016.
    bica se sviđa ovo.
  5. mamba65
    6,484
    4,294
    *All Menu whit Reflect icons, Provider & Sat Picons,All Services Info,All Crypto Info,All System Info *
  6. mamba65
    6,484
    4,294
    First I have to thank hmmmdada for its excellent converter, which has allowed me!
    1. Updating VTI Image
    2. Install EPG Share 3.0 from the feed otherwise crash is pre-programmed
    3. In EPG Share in Settings, set: Improve EPG with Extra Data - YES
    4. Download EPG Share manually
    5. Goliath_RV3_1080p_HD Install skin afterwards and GUI reboot
    - New menu with edit mode and picons display
    - 2 different InfoPanel
    - 4 different SecondInfo panels with Scoller text, SystemInfo, Event, Weather..uvsm ...
    - 2 different channel list / epg with scrolll text, event ....
    General for handling skinparts:
    VTi -> ">To activate this, you go to the receiver under Menu -> VTi ->
    Settings-Goliath_RV3_1080p_HD in the Goliath_RV3_1080p_HD proactivate to YES
    Yellow button and highlight the desired skinpart.xml.
    By pressing red, green, you leave the settings and are prompted to restart.
    This leads you through and the skinparts are active
    1 Open weather plugin from plugins browser
    2-Press Menu from the keyboard
    3-green button (Add)
    4-Type the name of the city in option (city)
    5 Click yellow buttons (search code)
    6 Select your city and press green (ok)
    7 Press the green (OK) button again
    8-Finished Exit Plugin button Press Exit button
      Veličina datoteke:
      149.7 KB
      Pregleda:
      66
      Veličina datoteke:
      608.7 KB
      Pregleda:
      68
      Veličina datoteke:
      247.4 KB
      Pregleda:
      69
      Veličina datoteke:
      153.9 KB
      Pregleda:
      67
      Veličina datoteke:
      187.4 KB
      Pregleda:
      69
      Veličina datoteke:
      189.9 KB
      Pregleda:
      67
      Veličina datoteke:
      314.6 KB
      Pregleda:
      67
      Veličina datoteke:
      129.3 KB
      Pregleda:
      65
      Veličina datoteke:
      254.1 KB
      Pregleda:
      70
      Veličina datoteke:
      173.2 KB
      Pregleda:
      65
      Veličina datoteke:
      116 KB
      Pregleda:
      64
      Veličina datoteke:
      340.5 KB
      Pregleda:
      71
      Veličina datoteke:
      153.7 KB
      Pregleda:
      66
      Veličina datoteke:
      311.3 KB
      Pregleda:
      65
    Posljednje uređivanje: 19. Siječanj 2017.
  7. mamba65
    6,484
    4,294
    * UPDATE *
    **** SkinParts<<
    ~ Goliath_RV3_1080p_HD ~
    *FOR > VTI 11.01 < Image*
    skin_InfoBar_BigFont.xml ****> kommt in /usr/share/enigma2/Goliath_RV3_1080p_HD/allScreens/
    Allgemeines für den Umgang mit Skinparts:
    Ladet euch die gewünschten skinpart.xml Dateien herunter, diese übertragt ihr per FTP nach
    Um diese zu aktivieren geht ihr am Receiver unter Menü -> VTi ->
    Einstellungen-Goliath_RV3_1080p_HD in die Goliath_RV3_1080p_HD pro
    Einstelungen und markiert die gewünschten skinpart.xml.
    Durch die Tastenfolge rot,grün verlasst ihr die Einstellungen und werdet zum Neustart aufgefordert.
    Dieses führt ihr durch und die Skinparts sind aktiv
    * UPDATE *
    **** SkinParts <<
    Skin_InfoBar_BigFont.xml ****> comes in / usr / share / enigma2 / Goliath_RV3_1080p_HD / allScreens /
    Download the desired skinpart.xml files, which you transfer via FTP
    / Usr / share / enigma2 / Goliath_RV3_1080p_HD / allScreens /
    Settings-Goliath_RV3_1080p_HD into the Goliath_RV3_1080p_HD pro
    And mark the desired skinpart.xml.
    bica se sviđa ovo.
  8. mamba65
    6,484
    4,294
    OpenDreamy FHD 1920x1080 v1.1
    One Skin More Images
    Additional plugins and new menus by mamba65
    This skin is a unique project that supports many images of different teams can be customized with the logo of the various teams.
    Reported bugs, missing panels, incomplete or incorrect panels, reported pli-based images to be included in the supported images.
    Actual Support
    Egami - ItalySat - Atemio4you - HDMU(*) - PKT(*)
    OpenATV - OpenPli - OpenVix - OpenMips - OpenRSI
    OpenNFR - OpenHDF - OpenDroid - OpenESI - OpenLD
    Skin from mr.mmark mod by mamba65!!
  9. mamba65
    6,484
    4,294
    <!-- ### Skin: ~ Skin-MB65-by_mamba65" ~ skin xml from: Matrix10 & info convert from MCelliotG ### -->
    <!-- ### You are not allowed to Mod and publish my skin without my permission ###-->
    <!-- ### Special applies this warning for member LUCEK SAT ### -->
    *For crash or improvements please a feedback*​
    *8-Done Quit plugin bu Press exit button​
    Please put the ipk in folder /tmp and install as
    opkg install --force-overwrite /tmp/*.ipk
      Veličina datoteke:
      174.4 KB
      Pregleda:
      6
      Veličina datoteke:
      101.2 KB
      Pregleda:
      6
      Veličina datoteke:
      131.1 KB
      Pregleda:
      Veličina datoteke:
      296.9 KB
      Pregleda:
      Veličina datoteke:
      94.1 KB
      Pregleda:
      Veličina datoteke:
      101.9 KB
      Pregleda:
      Veličina datoteke:
      185.5 KB
      Pregleda:
      Veličina datoteke:
      157.5 KB
      Pregleda:
      6
      Veličina datoteke:
      161.8 KB
      Pregleda:
      7
      Veličina datoteke:
      113.1 KB
      Pregleda:
      7
      Veličina datoteke:
      184.5 KB
      Pregleda:
    • enigma2-plugin-skins-skin-mb65_v1_all.ipk
      Veličina datoteke:
      4.2 MB
      Pregleda:
  10. mamba65
    6,484
    4,294
    - MediaSat Skin
    - only on ME-feed for downloading
    - For last ME 9.0 Image
    bica se sviđa ovo.
Status teme:
