[P] Long Range WiFi antena (3km) 5800MW 58dbi USB Clipper ( novo i nekoristeno )
Rasprava u 'Mali oglasi' pokrenuta od SATmax, 14. Srpanj 2016..
  1. SATmax
    2,763
    3,587
    Prodaje se navedena WiFi antena za hvatanje signala nova i nekoristena ( isprobana za potvrdu funkcionalnosti ) u originalnom pakiranju sa dodatnom opremom i CD driver-om. Moze se koristiti kao stolna antena ili kao vakuum-ska na prozoru ili drugoj povrsini. Isprobana na WinXP i Win7 kao i na Linux distrama.
    Uz BackTrack 4/5 ( Kali ) moze se "dosta" toga napraviti.
    Info:
    Jamstvo na ispravnost i besplatna dostava putem Tisak kiosk kurirske sluzbe.
    Podaci:
    The Wifi Wireless Adapter adopts distance coverage technology, with built-in high gain antenna easily advances your distance and performance. It fully supports the features and functional compliance of IEEE 802.11b/g. You can just plug it into computer’s USB port and enjoy incredible high-speed wireless network access.
    100% brand new and high quality.
    58dB directional high gain antenna, high sensitivity long range
    Range: Over 500-800 met. (indoor) / 3000 met. (outdoor) with connection
    Chipset: Ralink 3070 chipset
    Standards: IEEE 802.11 B/G
    Data rate: 802.11b: 11Mbps 802.g:54Mbps
    Data Modulation Type:
    IEEE 802.11b: (DSSS), 5.5/11Mpbs(CCK), 2Mbps(DQPSK), 1Mbps(CCK)
    IEEE 802.11g: (OFDM), 48/54Mpbs(64-QAM), 24/36 Mbps(16-QAM), 12/18Mbps(QPSK), 6/9Mbps(BPSK)
    Antenna: External Antenna
    Host Interface: Mini USB
    Output power: 23dbm(OFDM), 30dbm(CCK)
    Frequency range: 2.4GHz(ISM Band)
    Software: Security: 64/128-bit WEP encryption, WPA, WPA2
    Driver: Win XP SP3 / Win 2000 / Win Vista / Linux / Mac / Win7
    Operating Voltage: DC 5V±5%
    Support Soft: AP, BT3, BT4, PSP X-Link, 8187L
    Antenna dimension: Approx 24*Φ4.7cm
    Easy and Convenient to use
    Package Include:
    1 x Wireless USB Adapter (Without retailing packing)
    1 x High Power Antenna
    1 x CD-Rom driver
    1 x USB Cable
    1 x User manual
    Cijena: 200,00 HRk / 55,00 KM / 27,00 €
