PKT-Hyperion Enigma2
Rasprava u 'Amiko SHD-8900 Alien' pokrenuta od mixix, 17. Studeni 2014..
  1. mixix
    mixix Moderator
    18. Prosinac 2011.
    1,422
    192
    Sp
    Enigma2/Carefree Package Spark7111 PKT-Hyperion v3.2 mod by mui4tler
    Friday, 6:28 pm+5
    Release: 07/11/2014
    run on the following boxes:
    Amiko Alien SHD 8900
    Golden Media 990 CR HD PVR Spark LX
    Golden Spark Media Reloaded
    Pingulux
    Pingulux Plus
    Galaxy Innovations GI S8120
    SAB Unix F + Solo (S902)
    Dynavision Spark
    Fulan Spark I +
    Here are a gemoddetes PKT-Hyperion-V3-Image with the following changes:
    - Erstinstallationswizard
    - Pure E2 Backup
    - Samba Active: default-release for / hdd and / media
    - Teletext Font and size changed / improved
    - Radio logo in bright HDF-Style
    - Radiologo dark in PKT-Style
    - Alternative Radio mode
    - Current sender list Astra 19.2 Stand 11.2014 (thx googgi)
    - Various skins preinstalled: PLi-HD (active), including
    emu-panel:
    - Oscam emu-v9945
    - Pre-installed with matching configs and many predefined readers
    --- Oscam-Webinterfache on port 88
    audio.elf
    there is an alternative "audio.elf" used:
    advantage:
    - AC3 audio is now reliably output to SPDIF / HDMI
    - Volume difference between AC3 downmix and mpeg-stereo is thus far less
    - Volume of pure AC3 channels were now increases with "channel control" by 30%
    >> Differences in zapping should be minimal
    disadvantage:
    - Dts downmix does not work with it! (real dts output to HDMI / spdif course continue)
    - Various plugins pre-installed:
    - Navibar v1.8 >> the customizable menu extension on the red button
    - openwebif
    - Cooltv 7.0 guide (EPG in different views)
    - EMC 3.7 (Enhanced Movie Center)
    - Media Portal: Update to v.6.0.1
    - Media Info: Download Manager for Media Portal (call with REC button!)
    - Shoutcast Stream with Ripper
    - Infobartunerstate (shows current recordings with the Infobar to)
    - Dream Explorer
    - Advertising Zapper
    - Hdmi-cec: activate when needed
    - u.a.m
    Remote control adjusted (thx Data devil & markuschen):
    should now universal fit for all types of FBs - (! untested) for the 3 of Pingu
    OK = opens Channel List
    D-pad left / right in the Channel List = changes Bouquets / Favorites
    red = Navibar / extensions
    red-long press = Channel Controle
    green = Aspect ratio selection (+ Option> red)
    green-long press = Dimmer
    yellow = Audio selection teletext
    yellow-long press = Teletext
    blue = PKT-Blue-Panel
    blue-long press = Emu panel
    EPG = Cool-TV Multi-EPG
    EPG long press = EPG selection
    Portal = MediaPortal
    Portal-long press = Blue Panel
    FAV = Fav list
    SAT = satellite list
    Info = Info Panel
    Sleep = Sleep Timer
    Folder = starts EMC
    Play starts EMC =
    Pause = Timeshift
    Switch V-format = Acpect ratio directly
    find = System Info
    Timeshift Timeshift =
    F1 = Teletext
    Help F2 =
    F3 = Virtual Keyboard (where it goes)
    With the Key Mapper in the blue panel you can modify various keys yet to taste.
    Known bugs:
    * no
    telnet and webif are password protected:
    user: root
    pass: pkteam
    Youth protection Password: 0000
    - For xxx in station list
    - And for menu + Porn in Media Portal
    zatagic and mamba65 like this.
  2. emir_inter1
    emir_inter1 Forum Friend
    31. Srpanj 2009.
    765
    234
    PKT SVN-3072 HYPERION v4.5 Image
    SH4 Duckbox Project GIT-5767
    Added by PKT:
    [ALL] fix cam start at startup tuner
    [XPEEDLX] Add Correction time in deepstandby
    [ALL] fix scrollbar
    [SH4] add new WiFi Driver Manager
    - restart GUI is required to detect WLAN stick on main network setup
    - all drivers directly from GIT should be supported
    - 'try driver' can be selected only when all driver is inactive
    - eth0 is automatically up when 'disable driver' is selected
    [ARIVA] fix vfd plugin
    [ariva] GS fix on ledREC
    [SH4] samba update and 2GB fix
    [sh4] fix samba setup if IPV6 in kernel is enabled
    [sh4] update rtmpdump and librtmp for IPTV Player
    [sh4] eplayer image in NOR 32MB optimalization
    [SH4] SyncTime - fix update script
    [mips] fix tuxtxt encoding
    [sh4] Removed CrossEPG from image - now only on feed
    [sh4] add Remote Manager
    [sh4] add mount by LABEL in HDD Manager
    [spark] fix multiboot
    [UFS910] fix networking restart
    [MIPS] fix start/stop/restart emu on standby
    [MIPS] fix NetworkBrowser on sf8
    [MIPS] add hbbtv indicator on Silver & Red skin
    [ALL] fix detecting network interface and code optimization
    [SH4] fix esi cooler standby
    [MIPS] Shoutcast update
    [all] add Memory Cleaner
    [MIPS] fix Channel Control
    [MIPS] fix GS on InpuDevice
    [all] add NTFS to HDD Manager and ntfs-3g support
    [MIPS] fix Start DLNA server
    [MIPS] fix time correct on xpeedlx1
    [MIPS] fix showing CPU clock
    [ALL] add IPTV Player optimalisation
    [CUBEREVO] fix BootPlus
    [SH4] disable clear cache for UFS910
    [MIPS] add missing renderer for better skins compatibility
    [SH4] add UFS913
    [ALL] fix manual backup restore
    [MIPS] add mising files for LCD4Linux
    [ALL] many other bugfixes not included in this changelog
    Special THX to TDT, OpenPLI, OE-alliance and all betatesters.
    FTP login: root, passwd: pkteam
    Regards
    Pozdrawiamy Polish Koders Team
    zatagic, mirzav i mixix se sviđa ovo.
  3. turbo_s
    turbo_s Clan
    20. Veljača 2015.
    22
    7
    Gradacac
    kako se instalira ovy enigma
  4. tataos@
    tataos@ Forum Friend
    30. Ožujak 2013.
    472
    130
    skinuti, raspakairati, prebaciti na usb. najsigurnije je u sparku pomoću "enigma2 upgrade" plugina. upaliti rec, prebaciti na spark, ubaciti usb i kada ga prepozna otići na plugine i odabrati enigma2 upgrade. ne znam točno sada napamet ali mogu ti pomoći popodne poslije 18 ako u međuvremenu ne riješiš.
  5. turbo_s
    turbo_s Clan
    20. Veljača 2015.
    22
    7
    Gradacac
    ok hvala probaću tako da odradim aljda ce da uspije
  6. turbo_s
    turbo_s Clan
    20. Veljača 2015.
    22
    7
    Gradacac
    Hvala uspio sam instalirati sada imam jedno pitanje posjedujem Amiko Ralink RT5370 usb wifi dali postoji mogućnost da se pokrene na ovoj enigmi i kako ako neko zna postupak molio bi da pomogne.
    Ovaj isti wifi radi na Sparku i uredno povezuje resiver i router bezicno pa valjda moze i na Enigmi.
  7. tataos@
    30. Ožujak 2013.
    472
    130
    tu ti ne mogu pomoći, ali znam da taj model usb wifi mora raditi i na enigmi jer je rađen za amiko uređaje. kako sam čitao na forumu ipak je žica sigurnija za povezivanje. javit će se vjerojatno netko tko koristi usb wifi. mislim da trebaš samo nešto u postavkama napraviti.
  8. turbo_s
    turbo_s Clan
    20. Veljača 2015.
    22
    7
    Gradacac
    ok hvala pokušat ću nešto možda uspijem
  9. novakp
    novakp Clan
    9. Svibanj 2009.
    Pozdrav,
    vezano za enigmu 2 na ovom resiveru interesuje me preporuka za instalaciju verzije PKT. Koja je poslednja verzija koja može ići na Chipset ST7111. Malo istražujući kako se navodi poslednja je 5.5 ali ima ih više a neznam koja je odgovarajuća pa da nešto ne zabrljam i da li u tom slučaju mogu samo presnimiti drugu verziju ili je moram prvo brisati. Dakle preporuka za najstabilniju.
  10. bazen
    bazen Clan
    18. Prosinac 2014.
    20
    Total commander file list (copy)
    Total files: 1
    /storage/emulated/0/download
    BlackHole-3.0.2-spark-20160413.zip 65212242 2018-10-13 13:19:22
  11. novakp
    novakp Clan
    9. Svibanj 2009.
    Ima li preporuka za poslednji Hyperion image za Alien 1 koji je moguće instalirati
  12. buc61b
    buc61b Clan
    17. Srpanj 2013.
    83
    14
    Podgorica
    5.5 zadnji
    Poz
  13. novakp
    novakp Clan
    9. Svibanj 2009.
    U međuvremenu instalirao sam gm7162_GIT-357_PKT-3503-NP_pli_new_stm24-p0217_flash, ali ne mogu da podesim motor, tj pronadjem signal rucno na nekom satelitu ali kada vratim na listu nemam signala. Da li je potrebno da izbrišem prvo image (na koji način) i instaliram ovaj što je kolega buc61b naveo ili samo da nabacim novi. Hvala
  14. bazen
    bazen Clan
    18. Prosinac 2014.
    20
    Ako imas Amiko elien ubaci onaj gore black Hole Radi super.
