PowerVU Emu
Rasprava u 'DVB Emulators' pokrenuta od mixix, 4. Svibanj 2015..
  1. mixix
    mixix Moderator
    18. Prosinac 2011.
    1,419
    194
    Sp
    PowerVU Emu v.1.1
    Fix:
    Fixed glitches of DES mode.
    PowerVU Emu
    PowerVU Emu is an standalone emulator for DVB-Viewer-Pro.
    Usage:
    - Copy its .dll, .ini & Softcam.Key files to the `Plugins` folder of the DVB-Viewer-Pro.
    - Its key format is:
    P Ident KeyIndex Key ; Comments
    - Disable other plugins that are able to decrypt the PowerVU. Only one plugin is able to decrypt the same TS(Audio/Video) correctly at once. If you are using vPlug, you need to delete its PowerVU.mdl to disable its PowerVU support.
    - Also don't forget to use a better direct show filter, such as LAVFilters, to avoid glitches.
    History
    V 1.1
    - Fixed glitches of DES mode.
    V 1.0
    - First public release.
  2. mixix
    mixix Moderator
    18. Prosinac 2011.
    1,419
    194
    Sp
    PowerVuEmu v.1.5
    V 1.5
    - Added DVBDream support.
    Copy its .dll, .ini & Softcam.Key files to the `Modules` folder of the DVBDream. Then change the extension of the .dll file to .mod.
    - Improved the ECM decryption of CSA mode (MEASAT, 91.5E).
    V 1.4
    - Added CSA mode (30W 12092V, 4W 10842H).
    - Improved the PMT parsing.
    V 1.3
    - Added `keys auto try` mode. The Emu will try all of the available keys to find the working one automatically.
    It lets you to have duplicate idents for different channels.
    In this case, idents and indexes are not important anymore.
    - Both of these key formats are acceptable now (to avoid having duplicate idents):
    or
    P IdentVideoPidAudioPid KeyIndex Key ; Comments
    Such as:
    P F861 01 key ; bwtv, 13.0°E 11054-H-27500
    or
    P F86100D200C8 01 key ; bwtv, 13.0°E 11054-H-27500
    A key with `IdentVideoPidAudioPid` has a higher priority.
    VideoPid or AudioPid should be 4 characters long.
    V 1.2
    - Fixed PMT parsing of channels like `ID XTRA`.
  3. macro
    macro Administrator
    21,098
    15,419
    V 1.6
    - Added EMM support (Auto update).
    EMM Key format:
    P UA 00 EMMKey ; comments
    UA = Unique Address = 4 Bytes (8 characters)
    After entering your EMM key in softcam.key file, select the `Active` checkbox in EMM tab and wait.
  4. macro
    macro Administrator
    21,098
    15,419
    V 1.7
    - Improved the CAT section of the DVBDream's implementation.
    - Added a general MD-API support.
    MD-API support doesn't work right now. DVB-App developers need to change their applications slightly:
    1) PID = (PID | 0x8000) means please send TS-188, instead of TS-184.
    2) Use the modified TS buffer after its changes in the plugin.
    The plugin will change the Audio and Video buffers and these buffers shouldn't be immutable.
    This method is more general, maintainable and future proof.
    Let the plugins to do the CSA/DES part, by modifying the TS buffers and then use the modified buffer.
    The same method is in use for DVB-Viewer-Pro plugins and DVB-Dream modules.
    MD-API support partially works with TSReader (coolstf.com/tsreader). You can try `Options menu -> Record the decrypted Audio+Video` of the plugin.
    Which means requesting `PID | 0x8000` sends TS-188, but the modified buffer won't be used by the application.
    Also ProgDVB supports requesting `PID | 0x8000`. But it doesn't open the video and audio filters for encrypted channels.
  5. mixix
    mixix Moderator
    18. Prosinac 2011.
    1,419
    194
    Sp
    V 1.9
    - Added an offline .ts file decryption tab.
    It has the HSD (High Speed Data) decryption support too.
  6. mixix
    mixix Moderator
    18. Prosinac 2011.
    1,419
    194
    Sp
    History
    V 2.2
    - Improved EMM and ECM Decryption modes.
    Test your old EMM-Keys with PowerVU Emu 2.2. They should work again.
  7. shishmish
    shishmish VIP
    31. Srpanj 2010.
    1,053
    182
    West Banat
    13.10.2015
    mamba65 se sviđa ovo.
  8. mamba65
    6,660
    4,427
    V 2.3
    - Added `Antena 3/South America` support (A PowerVU variation with a special XOR mode).
    - Added record raw ECM option.
    commando se sviđa ovo.
  9. mixix
    mixix Moderator
    18. Prosinac 2011.
    1,419
    194
    Sp
    PowerVuEmu.3.0.0
    V 3.0.0
    - Added extra ECM bytes handling with 2 new modes: mode cw and mode unmask. Only modeCw/Unmask = 0 & 3 are implemented.
    They introduced `extra bytes` before and now they are calculating two modes from it: modeUnmask and modeCW. modeUnmask and modeCW = 0 are the same as before (using old hashes).
    For now mode 0 and 3 are implemented.
    This is a test. Give it a try.
  10. macro
    macro Administrator
    21,098
    15,419
    V 3.5.0
    - Fixed 166E issues.
  11. macro
    macro Administrator
    21,098
    15,419
    V 3.6.0
    - Added Compel support, 4.8E 12379 H (ATG EU BSS & K75 International).
    You can define these types of channels in `PowerVuEmu.ini` file, under the `others` section. Its format is `pmt:sid;`.
    bica se sviđa ovo.
  12. macro
    macro Administrator
    21,098
    15,419
    V 3.7.1
    - Improved Rosscrypt1's key detection.
    bica se sviđa ovo.
