Top 3 Octa-core Android TV Boxes of 2017
Rasprava u 'Ostali Android IPTV svi Modeli' pokrenuta od mamba65, 10. Kolovoz 2017..
  1. mamba65
    6,665
    4,418
    Amlogic Octa-core CPU S912 is hot for TV Box. We have done much research on the OTT market. Here are the best Octa-core Android TV Box models recommended for you:
    NO.1
    Sunvell T95Z PLUS TV BOX Amlogic S912 Octa Core Android 6.0
    This model’s 16GB of storage and 2GB of RAM are double than other top boxes. The Octa Core S912 processor blows the competitors away with its amazing speed.
    “Item was easy to setup, ready to go on additional downloads, and runs just like standard droid items! **side note, if you want to use Amazon Prime on this, you have to adjust your security settings to download and install from unknown location, download and install amazon underground, THEN download Amazon Video for Prime access. That hassle is on Amazon though** would totally buy this again over a roku!”
    NO.2
    T96 Pro TV Box Android 6.0 Marshmallow Amlogic S912 Octa Core
    T96 pro smart tv box with a newest and open platform Android 6.0 Marshmallow, pre-installed with a media center software that enables you to play all your video and audio files on your TV . No more watching them on a small PC screen.
    “For the price of this box, I was almost hesitant on ordering it, but when I received it and plugged it in I knew this was going to be a great product. The price for what you get is less than what is packed into this awesome Android TV Box. The thing that really got me into this product is the user-friendly interface. I’m so used to the Apple TV that it would be hard for me to swap from AppleTV OS to Android OS, and this was a breeze to learn!”
    NO.3
    Beelink GT1 TV Box Octa Core Amlogic S912
    The Beelink GT1 featuring the latest processor. It is equipped with the Amlogic S912 CPU which enables you to have a smooth entertainment experience. It also has a 3D noise reduction filter.
    “The box can connect with internet wirelessly or via Ethernet and has Android version 6.0 (Marshmallow), with 2G Ram/16G storage. You will be amazed of all the things you can do with this TV box. It will blow your mind if you never had one, I love mine and have one on every TV in my home.”
    benes-m se sviđa ovo.
  2. Coolmer
    Coolmer Clan
    21. Studeni 2010.
    36
    Slazem se za onaj box na vrhu. Samo skup.
  3. Dr.Graf
    Dr.Graf VIP
    28. Siječanj 2018.
    55
    24
    h@xx
    in your computer
    Ama za S912 bazirani box nije skup - za nekih 70-ak dolara ga se može nabaviti iz Kine. A ja znam gdje se u HR može nabaviti za malo više od 100€ s PDVom, računom, garancijom...
    Ova tri boxa gore bazirana su na S912 koji je i dalje top SoC za TV-boxove. Zamjeram Amlogicu što su neke rezolucije izostavili kod hardverskog dekodiranja H.264, iako se te rijeđe trebaju pa nije veliki problem...
    U top ligu sad upada i Rockchipov RK3399 koji je six-core (2 Cortex-A72 + 4 Cortex-A53), što su jače jezgre od S912, a i jači GPU Mali-T860 MP4 (kod Amlogica je to T820) ... cijene boxova baziranih na tom chipsetu su u Kini od $130 pa naviše.
  4. zaim
    zaim Clan
    6. Kolovoz 2009.
    Da li neko ima iskustvo sa TX3 mini 2gb/16gb??
