Ultra HD Glass 18
Rasprava u 'ENIGMA 2 OE 2.2' pokrenuta od vusolo2, 16. Studeni 2017..
  1. vusolo2
    vusolo2 Forum Friend
    15. Prosinac 2015.
    482
    138
    slovensko
    Ultra HD Glass 18 ver. 0.17
    Ultra HD Glass18 is the next generation of HD Glass family skins usuable with HW and OS with support of Ultra HD skins f.e.: DM900UHD and Dream OS
    - first alpha version (non public)
    Ultra HD Glass 18 ver. 0.75
    - first beta version
    - current state of work: 75%
    Ultra HD Glass 18 ver. 0.95
    - current state of work: 95%
    Ultra HD Glass 18 ver. 1.03
    - current state of work: 97%
  2. vusolo2
    15. Prosinac 2015.
    482
    138
    slovensko
    - Ultra HD Glass 18 (UHDG18) IS ULTRA HD NATIVE SKIN SO BEFORE INSTALLING PLEASE
    CHECK IF YOUR CURRENT IMAGE SUPPORTS ULTRA HD SKINS
    - UHDG18 is independent skin and can be used simultaneously with HDG16 and FHDG17
    - test was provided on hw: dm820, dm900, dm920 with latest DMM exp. image(OE2.5
    including latest updates)
    ipk version is and will be still unpublic because do not exists image with support OSD/skin in Ultra HD mode and please, do not ask about publishing of ipk version
    ipk verzia skinu je a bude stale neverejne pretoze neexistuje ziaden image s podporou OSD/skinu v Ultra HD mode, prosim, neziadajte o zverejnenie
  3. vusolo2
    15. Prosinac 2015.
    482
    138
    slovensko
    - updated: pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt, fr
    - updated enhanced weather translations: sk, cz, et, lt
    - fix/corections some extra screens
    - added enhanced method of picon searching
    - fix CAID:PID info
    - WEATHER: YAHOO - added option Show yesterday
    - WEATHER/ENHANCED WEATHER: fix colors table
    - fix audio trak type AAC detection
    - added detection tuners: A1 - A8, B1 - B8 (after restore icons type will be set
    to default type 1, so after update and autorestore you must download icons and
    previews and then set/select your prefered icons type)
    - DOWNLOAD MENU: updated icon sets and previews
    - EXTRA INFOBAR: added option Tuner info with options - real data from tuner,
    transponder info
