ViX4E2PROJECT Version 1.0 Build 006
Rasprava u 'GigaBlue IpBox Images' pokrenuta od mamba65, 13. Prosinac 2014..
  1. mamba65
    6,349
    4,225
    System OE: OE-Alliance 2.3
    Distro: ViX4E2PROJECT
    Firmware version: 1.0.006
    What's new in this build
    ADD GIGABLUE HD RANGE - New builds for all GigaBlue Plus range of E2 MIPS receivers
    UPDATE E2 TO SUPPORT GBIPBOX - Add full support for gbremote-client (E2 IPTV local streaming)
    UPDATE KERNEL VERSION ON EVO ENFINITY - To latest available 3.14.2 kernel version
    INCLUDE ALIEN2 VFD TIME DISPLAY FIX AS STANDARD - To ensure correct time is shown on front display
    BRING ALL SUPPORTED MODEL BUILD VERSIONS INLINE - To ensure all makes/models are on same build version
    UPDATE PICONS FEED TO UNIVERSAL - Ready for additional plugins to be added to the server which are universal to all supported makes/models. For future use with channel lists, picons and universal third party plugins
    Complete online image flash, backup and restore options are available - meaning you can update to the very latest version, keep your settings and all without the need to leave your chair! (see below)
    Set third tuner to DVB-C by default (Amiko Alien 2 / Alien 2+ supported models only)
    DOWNLOAD USB IMAGE UPDATE
    AVAILABLE AS ONLINE DOWNLOAD/FLASH DIRECT FROM THE RECEIVER MENU
    Blue Button > ViX4E2PROJECT > Image Manager > Downloads
    YOU ARE ALSO ABLE TO BACKUP EXISTING SETTINGS FROM VERSION 002 ONWARDS WITH THE OPTION TO RESTORE TO THE NEW VERSION IMAGES EITHER AT FIRST BOOTUP AS PART OF THE SETUP WIZARD (just perform the backup, flash the new image and you'll be given the option to restore during the setup wizard) OR LATER THROUGH THE BUILT IN RESTORE MENU OPTION
    Blue Button > ViX4E2PROJECT > Backup Manager > Restore
    IF USING THE ONLINE FLASH OR BACKUP OPTIONS MAKE SURE YOU HAVE A USB STICK INSERTED INTO THE RECEIVER SO THERE IS SOMEWHERE TO STORE THEM!
