This content is protected This content is protected This content is protected Vu+ Zero Features: • Opera browser • HbbTV • HDMI 1.4 connection • DVB-S2 tuner • External 12 V power supply Technical Highlights: • 2K DMIPS processor • DVB-S2 tuner • 256MB Flash • 512 MB DDR3 DRAM • 1 x Smartcard-Reader (Xcrypt) • 2 x USB • 10/100 Mbit Ethernet Interface • 1 x HDMI 1.4 video / audio output (digital) • 1 x RCA video output (analog) • 2 x Audio Output (L / R) RCA (analog) • unlimited channel lists for TV / Radio • EPG (electronic program guide) support • Support of favorite lists (bouquets) • OSD in many languages and skin-support • expandable with plugins • Automatic / manual channel search • DiSEqC 1.0 / 1.1 / 1.2, USALS • External 12V power supply • Power switch Vu+ Zero Specifications: • DVB-S2 tuner: • Input Frequency Range 950 ... 2150 MHz • Input level range - 65 dBm ...- 25 dBm • Tuner Input Connector F connector • Input impedance 75 ohms • AFC capture range +/- 3.5 MHz • Demodulation QPSK and 8PSK • Viterbi and Reed-Solomon FEC • Viterbiraten 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9 • Roll-off Factor 35% Video decoding: • Video compression MPEG-2 / H.264 and MPEG-1 compatible • Video Standard PAL G / 25 Hz, NTSC • Aspect Ratio 4: 3/16: 9 • Letterbox for 4: 3 TV-Device Analog output: • Output Level L / R 0,5 Vss on 600 Ohm • THD> 60 dB (1 kHz) • Crosstalk <-65 dB Video parameters: • CVBS input level 1 Vpp +/- 0:25 dB at 75 Ohm Ethernet: • 100/10 MBit compatible interface USB: • USB 2.0 connection (2x) LNB power and polarization DVB-S2 tuner: • LNB Current 400mA max. Short-circuit protected • LNB Voltage horizontal without load 19,5V17,6V at 400mA • LNB Voltage vertical load without 14.5V 11.8V at 400mA • LNB is switched off in standby mode Control of the satellite position: • DiSEqC 1.0 / 1.1 / 1.2 and USALS - Rotor Control Power Consumption: • <13W (in operation, with LNB) • <12W (in operation, without LNB) • <0.5W (Deep-Standby-Mode) Input: • External power supply: • Entrance: • 110-240V AC / 50-60Hz / 1,0A • Exit: • 12V = / 3,5A General: • Ambient temperature + 15 ° C ... + 35 ° C • Humidity <80% • Dimensions (W x D x H): 211 mm x 185 mm x 40 mm Contents of Box: • Satellite Receiver (Vu+ Zero) • Remote control • Batteries • Cable for analog A / V outputs (3.5 mm jack) • External IR sensor • External power supply • User manual
Imao sam ga par dana Moram priznat mala škrabica radi vrlo dobro Image blackHole, probao sam i openpli al imam osjeaj da je BH više frendlyuser. Istina, na Openpli imageu HDMI radi s mojim Philipsom 9806, gasi TV sa gašenjem resivera BH to ne radi zamjerka ne radi Youtube trazio na netu neke zakrpe i svaki put ubio resiver (ponovo flešanje i iz ispočetka) nisam uspio upogonit ni subtitle, istina do sad mi je bio domet Dbox2 i enigma1 Ono što me dojmilo je prebacivanje kanala neovisno kodirani ili ne daje sliku za manje od sekunde SD kanali su OK s kvalitetom slike a HD moram priznat ko moj Topfield7700HSCI koji je bio 3x skuplji u ono doba nego ova škrabica moja preporuka
Pomoc oko vu zero:Sve radilo ok zadnjih par dana nestalo mi signala na htv obn bn i vecini H frekvencija dok V rade to vazi samo za eutelsat dok astra radi ok.Probavao sam par imiga ali isto liste knala nanovo ista stvar.Nemam objasnjenje zasto astra radi a 16 ne Hvala unapred.
jesi li možda ubacivao svježu listu pa ti od onda ne radi, pokušaj ubaciti listu sa SESE editorom da vidimo da nije do liste.
Probao sam sve i sa novim imigom takođe sam probao orginalni imig i skeniranje frekvencije ali ništa.Znaci svi rade osim Eutelsat OBN Htv Rtrs i još nekoliko svi sa H
