Alma HD Tools
RS232 loaderi
RS232 Loader Software za Alma S2200
RS232 Loader Software za Alma S2000 - S2100
Serial loader procedure
- power off the STB
- connect your PC and STB with a serial null-modem cable
- start the appropiate loader program
- browse for the FW file
- do not check "include bootloader" !!!
- click on NEXT and power on the STB
- wait till "Finished" message
- then click NEXT to start burning into flash
- isključiti resiver (na prekidaču ili iz napona)
- spojiti PC i resiver preko null-modem kabela (rs232)
- startati program alma loader
- odabrati sw file za ubacivanje (.abs)
- ne uključivati "include bootloader"
- pritisnuti tipku NEXT i upaliti resiver
- pričekati do se ne pojavi poruka "Finished"
- kliknut NEXT za startanje ubacivanja programa u resiver
- proces ni u kom slučaju ne prekidati dok se ne zavši
Ariva - Alma HD (3606) Editor
Switching from. Udf in. Abs file
- download the dump file xxx.abs the receiver (or use an existing) on the computer
-. Udf file open with Ariva 3606 editor
- Click on File and choose Export
- Choose the file type *. Abs and will appear in the selected dump file xxx.abs
- Save the file to the dump file xxx.abs
- If you want to replace the existing file - the select YES
- If they have made ​​changes to select the User Data Base
- Dump file xxx.abs record to USB
- With USB and options userdb record in receiver
Prebacivanje iz .udf u .abs fajl
- skinuti dump file xxx.abs sa resivera (ili koristiti neki postojeći) na kompjutor
- .udf file otvoriti sa Ariva 3606 editorom
- kliknuti na File i odabrati Export
- izabrati vrsta datoteke *.abs i pojavit će se i odabrani dump file xxx.abs
- spremiti datoteku u dump file xxx.abs
- da li želite zamijeniti postojeći file - izaberati DA
- ukoliko su rađene promjene odabrati User Data Base
- dump file xxx.abs snimiti na USB
- sa USB i opcije userdb snimiti u resiver
m.d
Yasto ne mogu da apdejtujem softver na hd2220 preko pc/a,javlja set stb memory error,imam problem sa resiverom,samo stoji vrijeme na ekranu i nista ne prikayuje,sa usb/om se ne moye apdejtovati jer nemam sliku na ekran i ne pali se resiver,samo stoji sat
