Alt-DVB v2.2 B3912 Full
Zorro
Info:
Warnings:
- Premium cards (SkyStar1) not supported anymore.
- Old interfaces (Dev_???.int) are not compatible with new app.
Application:
* MPEG4/AVC Stream parser & demultiplexer
* Multi-monitor support
* Support for DVB-C/DVB-T/ATSC
* Multiple cards selector
* EPG/Channel (in main window)
* Mouse wheel actions
* New configuration window
* Process priority option
* Improved channel scanner
* Popup menu from tray icon
* Channels list can be filtered by satellite
* PIP1-3 selection buttons
Interfaces:
* New: BDA Driver
- DiseqC: Raw diseqc support for Twinhan BDA drivers
- DiseqC: LNB1-4 select for DvbWorld
- DiseqC: LNB1-4 select for Technotrend (via put_Range() )
* New: DVBWorld
- RawDiseqC not suported now. (see Dev_DvbWorld.cfg)
* SkyStar2 :
- RawDiseq for SS2 new driver (4.4.0)
- Many changes in "Internal" PID filter
Fixed:
* Signal indicator for SS2 & driver 4.4.0
* Popup menu exception on ES/CA window if no ch. selected
* Adjust GOTO with location NOT saved !
* Fixed CPU usage indicator for dualcore/HT processors
* Fixed PTS in DvbAvSrc.ax
[logged]http://www.skystar-2.com/download/AltDVB2.2.exe[/logged]
mixix
Moderator
BDA Interface For AltDVB v02021
*Version 02021 - 2013-07-31 by CrazyCat
*Fix Pinnacle 4xxe USB2.0 support (Technotrend BDA).
[B]This is a new BDA interface wrapper for AltDVB v2.2.
The configuration file (Dev_Bda2Driver.cfg) should be placed in the same folder
as the interface (Dev_Bda2Driver.int).
If this file doesn't exist, the interface driver
will create a new one with default values.
S2 Pilot and S2 Roll Off:
these values are for the Haupppauge drivers and practically
should not be changed[/B]
