Auto Swap E2 Plugin
Auto Swap E2 Plugin​
Due to the current discussion, it is now I have become too stupid and I did as I broached a car swap plugin.
The plugin is if it is installed at boot each is found on a on / media / xxxx mounted device if a file named swapfile on it beswappen also, and all partitions on the devices with the Type 82 Linux swap so were partitioned.
But that is ONLY about you turning on the swap easier without stupid fstab entries or the like, so the feature is always on when the plugin is installed.
The real car swap thereof when the recording is in progress or a shift starts within a few seconds, the swapfile DISABELT and only when no recording and no longer active timeshift automatically the swapfile back turned.
Cat / proc / swaps can see the plugin in the telnet Aurbeit if your testing.
And yes there are also several swapfile / swap partitions go if anyone has such strange ideas.
This should then actually despite active swapfile the lags in the recordings of the past.
Is not the solution I would have liked, but to test it's still worth it all.
And NO, create the actual swap file is not intended for the car swap plugin that can wonderfully diverse tools and wiki, it is also how to make swapfile or swap partitions.
To setup the system can Autoswap during recording / timeshift enabeln disabeln or even.
Most beautiful times and give some feedback if so despite normal operation active swapfile stuttering has to happen in the shooting in the OE 2.0 Images more.
