DGS Settings by Morpheus883
DGS Settings 31st October 2012 © by Morpheus883:
Settings for Images based on DGS firmware (compatible with every image)
MONOFeed (13°E)
DUALFeed (13°E + 19.2°E)
** Integrated Data/Test Services for Feed Hunters
*** Optimized for Setting Manager Plugin
*** Sma®t installation by Spippolo (compatible with all DB releases)
Pls, post your feedback (errors, mistakes & comments): your support is very important and more than appreciated
====== © by Morpheus883, 2012 =====
Instructions:
These settings are specifically created for DGS images: they don't work with any Enigma (1-2)
You can:
* download them directly from SifPanel
* upload them with the latest PCEditor release available.
Pls, do not forget to change LNB parameters and Receiver Settings according with your antenna/STB systems.
DGS Settings 30th November 2012 © by Morpheus883:
Motor - FULLFeed (45.0°W - 75.0°E) - NEW
Instructions:
You can:
Now available in tar.gz format too, packed for Sma®t installation & Setting Manager Plugin
