DiabloCam 2 " Pro" ( Files )
elgeneral
29.07.2012
12
21
München
Diablo Cam 2 "Pro"
D-Module PROFESSIONAL (PRO) description:
Based on Duolabs technology D-Module is a fully programmable PCMCIA module dedicated to DVB compliant STB-CI applications known as CAM (Conditional Access Module). D-Module is designed to give maximum flexibility and power for developers all combined with high security features to enhance the possibility to host a secure CAS.
The Diablo CAM 2 PRO is a Professional Conditional Access Module based on ARM7TDMI processor running at the speed of 50Mhz combined with a powerful FGPA and is capable to descramble up to 64 PIDs simultaneously.
The Diablo CAM 2 PRO is fully compliant with ETSI EN-50221 standard and it is tested on most of Professional MultiPID Transmodulators. The Diablo CAM 2 PRO has one smartcard reader ISO 7816 and one smartcard reader in SIM format.
The Diablo CAM 2 PRO is ideal for multi-room installations such as Hotels, Condos and generally any Transmodulated Multiservice Environments.
Why D-Module?
D-Module is uniquely designed, as product that differs from others in that it allows you the fully customize your design thanks to the flexible structure of the internal FPGA. All the known CAM modules in the market are based on an ASIC design in order to reduce the costs of each single device but sensibly reducing the customizable features and disclosing sensitive information about the eventual CAS and its structure and disclosing security information.
Hardware:
•ARM7TDMI @ 50Mhz.
•FPGA @ 100Mhz processing speed.
•RAM: Internal 16KB and External 1024KB.
•ROM: 256KB Internal Flash and 2MB Dataflash.
•J-tag connection.1 Smartcard Readers Plug-In.
•2 Unique serial Numbers internally lasered inside.
•Wi-Fi 802.11g connection at 54Mbit/sec.
•64 PIDS descrembling on 32 Channels.Software:
•PICO-OS Operating System.
•Dataflash internal Filesystem FAT 12.
•Fully programmable by PCMCIA secure protocol.
•WEP/WPA/WPA2 WLAN security encryption.
Are you a Broadcaster, CAS provider, System Integrator orContent provider?
If you are a CAS provider, Broadcaster, System Integrator or a Content provider you can feel free to contact us.
We can provide you will specification for a fast implementation and customization of your D-Module.
This is the easiest and fastest solution ever around!
Original Soft for Diablo 2 PRO
Version: pro-101
Reactions: 1 person
