Golden-Teletext
21.098
15.429
Golden-Teletext
Golden-Teletext 1.00
- This is MD-API plugin to show teletext with DVB applications.
- It supports level 1 and 1.5.
- level 1 (G0 Primary Sets and Latin National Option Sub-sets),
Level 1.5 (G2 Supplementary Sets).
- Unicode is supported, including continues characters(Arabic for example)for both of win9x and winNT.
- Save all teletext pages in memory for fast navigation.
- Can save current page as bmp.
- Can use any font as long as it supports the desired language(Unicode) and or teletext fonts.
- Many thanks to Christian Hackbart, Epmak and bisswanger
It can be used with any application supports MultiDec API
Tested with the following applications:-
ALT-DVB, DVBdream, progdvb and WatchTVPro Ex.
MyTheatre and RitzDVB using MDWrapper.
Dvbviewer using SoftCSA.
How to use?
Just copy GoldenTTX.dll to Plugins folder.......
AltDvb\plugins
dvbdream\Plugins\pip00
ProgDVB\Plugins
WatchTVPro Ex\Plugins
MyTheatre\MDPlugins
RitzDVB\MDPlugins
DVBViewer\MDPlugins
You can use the following keys for navigation:-
"up" and "down" arrow keys for page+ and page- respectively.
"Right" and "left" arrow keys for sub page+ and sub page- respectively.
"page Up" step forward by 10 pages, "page Down" step backward by 10 pages.
"Home" go to page 100.
Mouse actions:-
"D-click" to toggle fullscrean.
"R-click" to select language, font and save current page
21.098
15.429
Golden-Teletext 1.20
- This is MD-API plugin to show teletext and teletext subtitles with DVB applications.
- Unicode is supported, including continues characters(Arabic for example)for both of win9x and wint.
- Can save current page as bmp and or Unicode text.
- Can set time via teletext.
What is new?
- New function to set time via teletext.
- Can save current page as Unicode text (beta).
- Any 3 digits will be a hyper link, click it to switch to this page number.
- press "Back space" to recall previous page.
- press "F" to toggle full screan.
- Press "Esc" to exit full screan.​
21.098
15.429
Golden-Teletext 1.30
What is new?
- Add mouse control to perform Page+, Sub Page+ ,...etc by mouse.
* This update may be useful for latest version(s) of ProgDVB 6.xx.
* To use it, R-click then select "Show mouse control".
