IPTV STB Emulator Pro 0.8.01
30.12.2012
6.825
4.552
crosatelite.com
IPTV Set-Top-Box Emulator.
Pro-version:
* Ad free
* Less apk size
* Supports software remote controls for MAG 250
Keep in mind that this app is configured for a demo IPTV portal for testing purposes. If you want to use it you have to configure the app for your IPTV provider. It can work with IPTV portals that support MAG2xx/AuraHD boxes.
The app doesn't support m3u (or any others) playlists!
NOTE: This app is designed to be used by experienced users. To work correctly it must be configured first and if you've never configured STB MAG 250/Aura HD it may be difficult for you to configuring it. Keep in mind, that this app contains a lot of settings that has to be configured before it may be used by a user (read wiki first). If you do something wrong you may make the app unable to work.
https://dailyuploads.net/x1ru0qe8ntcg
Reactions: bica
