Lastest Drivers for DM 500HD
josip11
crosatelite umirovljenik
09/03/2011
dreambox-dvb-modules.bb
- worked on dm800 hdmi connection lost problem
- fixed load average calculation again (broken since 20110302 drivers)
- worked on h264 buffer underflow problems on some h264 services
01-05-2011
New update dm500hd hardware drivers
- hotfix freeze after some channel changes
- throttled mpeg decoder debug output a bit
- fixed bcm4506 tuner crash (no hab ack messages in kernel debug)
- fixed bcm4506 manual LDPC FEC modes
- fixed readback of current pilot state for dvb-s2 frontends (needs a linuxtv api fix)
- readback corrected symbolrate and frequency for bcm4501 and bcm4506
- cxd1981 DVB-C optimizations hardware drivers
21-08-2011
dreambox-dvb-modules: update dm500hd hardware drivers
- added 3D framebuffer support (for side by side and top and bottom 3D services)
(no auto detection yet)
- fixed audio sync problems on playback to live transition
- bcm4505/06
* experimentally added blindscan support (needs e2 changes)
* experimentally added "Turbo FEC" support (needs e2 changes)
* added constellation buffer read support
* fixed problems when more than one 4505/4506 tuner is used in the same box
* fixed standby problems
* added possibility to use SCPC optimized search ranges
- alps-bsbe1-c01a
* fixed locking problems (better performance)
- bcm4501:
- cxd1981: fixed tuner problems after bootup from deepstandby in DVB-C mode
- added Nagra rev. 1.1 CI support to dm8000
- small alsa signed / unsigned fix
Drivers 02/02/2012 in tar.bz2 format
http://www.2shared.com/file/SoA_QBx6/dreambox-dvb-modules-dm500hd-2.html
03-02-2011
update dreambox hardware drivers
- cxd1981(hybrid DVB-C/-T) increased max. frequency to 900Mhz
- cxd1981(hybrid DVB-T) fixed ineffective 5V for active antennas after mode change
- bcm4505/6 improved receiption sensitivity (fixes problems with small dishes since blindscan support)
dm500hd,dm800se,dm7020hd: fixed audio volume boost on alsa playback
dm7020hd:
- fixed frequently "error code 0x18006" messages on bootup
http://www.2shared.com/file/mtWXfber/dreambox-dvb-modules-dbg_2618-.html
http://www.2shared.com/file/Fbjrr3l0/dreambox-dvb-modules_2618-74-d.html
http://www.2shared.com/file/kr9kvqkf/dreambox-dvb-modules-dev_2618-.html
Agent X
- fixed strange aliasing noise on PCM Playback with needed upsampling
- finally fixed hybrid DVB-C/-T Tuner 5V output for active antennas
- don't fallback to DVI when the HDMI EDID was not readable
(this fixes some HDMI audio/video problems)
dreambox-dvb-modules_2.6.18-7.4-dm500hd-20120209-r0_dm500hd.rar (1.93MB)
dreambox-dvb-modules-dbg_2.6.18-7.4-dm500hd-20120209-r0_dm500hd.rar (869B)
dreambox-dvb-modules-dev_2.6.18-7.4-dm500hd-20120209-r0_dm500hd.rar (841B)
Agent X
Drivers DM 500 HD OE1.6 16.02.12
update dm500hd, dm800se, dm8000, dm7020hd and dm800 hardware drivers
- fixed overflow on aspect ratio calculation
 this fixes possible wrong scaled content
 - fixed scale factor calculation for dm800
 i.e. fixes wrong scaled IPTV services
 - fixed non transparent framebuffer after bootup
 this fixes not visible bootlogo before e2 starts on dm800
Update: OE2 Driver
update dreambox hardware drivers:
- fixed DVB-T with tda1004x based NIM
- fixed HDMI/DVI mode detection bug
http://uploading.com/files/5d239c5m/dreambox-dvb-modules_3.2-dm500hd-20120518-r7.0_dm500hd.rar/
New Driver DM500hd (OE1.6)
[HR][/HR]
Update Driver 3.2.3
-dreambox-dvb-modules: update OE1.6 dreambox hw drivers
- fixed not working "dm7020hd" remote control with dm800se and dm500hd after fp update
- fixed demux bug
- small CI fix
08.06.2013
- fixed AAC problems (dm800se, dm500hd, dm7020hd)
- added support for more samplerates to alsa driver (not dm800)
- fixed boot progressbar position (dm7020hd)
- small stability improvements
OE2.0 Driver Update
30/12/2013
Quote:
dreambox-dvb-modules: update dm800, dm500hd, dm800se, dm7020hd, dm800sev2, dm500hdv2 hw drivers
- fixed retune on signal lost for cxd1981 tuner (DVB-C/-T hybrid)
- fixed possible crash on last demux filter stop
- fixed possible demux buffer overflows on high bitrates
  • Driver Update 17.06.2014
  • update dm7020hd, dm500hd, dm500hdv2, dm800se, dm800sev2 hardware drivers
    dm7020hd
    - fixed WMA support (broken since 20140603/04)
    - added support for container aspect ratio override (e.g. MKV)
    - check (HDMI/DVI) audio formats on every hotplug event
    (this fixes sometimes broken AC3(+) audio passthrough after bootup)
    - fixed possible crash on driver initialization
    - optimized interrupt handling code a bit
