Lastest Drivers for DM 800HD
09/03/2011
dreambox-dvb-modules.bb
- worked on dm800 hdmi connection lost problem
- fixed load average calculation again (broken since 20110302 drivers)
- worked on h264 buffer underflow problems on some h264 services
01-05-2011
New update dm800 hardware drivers
- hotfix freeze after some channel changes
- throttled mpeg decoder debug output a bit
- fixed bcm4506 tuner crash (no hab ack messages in kernel debug)
- fixed bcm4506 manual LDPC FEC modes
- fixed readback of current pilot state for dvb-s2 frontends (needs a linuxtv api fix)
- readback corrected symbolrate and frequency for bcm4501 and bcm4506
- cxd1981 DVB-C optimizations
21-08-2011
dreambox-dvb-modules: update dm800, dm8000, dm800se, dm500hd hardware drivers
- added 3D framebuffer support (for side by side and top and bottom 3D services)
(no auto detection yet)
- fixed audio sync problems on playback to live transition
- bcm4505/06
* experimentally added blindscan support (needs e2 changes)
* experimentally added "Turbo FEC" support (needs e2 changes)
* added constellation buffer read support
* fixed problems when more than one 4505/4506 tuner is used in the same box
* fixed standby problems
* added possibility to use SCPC optimized search ranges
- alps-bsbe1-c01a
* fixed locking problems (better performance)
- bcm4501:
- cxd1981: fixed tuner problems after bootup from deepstandby in DVB-C mode
- added Nagra rev. 1.1 CI support to dm8000
- small alsa signed / unsigned fix
Drivers 02/02/2012 in tar.bz2 format
http://www.2shared.com/file/LV26YswS/dreambox-dvb-modules-dm800-261.html
03-02-2011
update dreambox hardware drivers
- cxd1981(hybrid DVB-C/-T) increased max. frequency to 900Mhz
- cxd1981(hybrid DVB-T) fixed ineffective 5V for active antennas after mode change
- bcm4505/6 improved receiption sensitivity (fixes problems with small dishes since blindscan support)
dm500hd,dm800se,dm7020hd: fixed audio volume boost on alsa playback
dm7020hd:
- fixed frequently "error code 0x18006" messages on bootup
dreambox-dvb-modules_2.6.18-7.4-dm800-20120202-r0_dm800(1).rar
dreambox-dvb-modules-dbg_2.6.18-7.4-dm800-20120202-r0_dm800.rar
Agent X
Agent X
Drivers DM 800 HD OE 1.6 16.02.12
update dm500hd, dm800se, dm8000, dm7020hd and dm800 hardware drivers
- fixed overflow on aspect ratio calculation
 this fixes possible wrong scaled content
 - fixed scale factor calculation for dm800
 i.e. fixes wrong scaled IPTV services
 - fixed non transparent framebuffer after bootup
 this fixes not visible bootlogo before e2 starts on dm800
Update: OE2 Driver
update dreambox hardware drivers:
- fixed DVB-T with tda1004x based NIM
- fixed HDMI/DVI mode detection bug
http://uploading.com/files/8e7c5529/dreambox-dvb-modules_2.6.18-7.4-dm800-20120518-r7.0_dm800.rar/
OE2.0 Driver Update
30/12/2013
Quote:
dreambox-dvb-modules: update dm800, dm500hd, dm800se, dm7020hd, dm800sev2, dm500hdv2 hw drivers
- fixed retune on signal lost for cxd1981 tuner (DVB-C/-T hybrid)
- fixed possible crash on last demux filter stop
- fixed possible demux buffer overflows on high bitrates
