Lastest Drivers for DM8000HD
Drivers 8000HD 15.12.2010
15 Dec 2010
dreambox-dvb-modules.bb: update dm800/dm8000/dm500hd/dm800se hardware drivers
- do more work on "rare PAT timeout problems after deepstandby wakeup"
- fixed pcr problems (fixes frequently deformed live audio output on dm500hd/dm800se)
- fixed small demux problem (dm8000/dm500hd/dm800se)
Lastest Drivers for DM 8000
02-03-2011
dreambox-dvb-modules.bb: update dm8000 hardware drivers
- reentrancy fixes in demux and video/audio clip mode (fixed frequently kernel oops)
- fixed not visible PEP options on DM8000
- revert to previous video output, hdmi and video decoder code (DM500HD/DM800SE/DM8000) this should fix some problems introduced with 20110215 drivers
- added pcr/hdmi kernel debug output messages to debug hdmi problems (DM800)
01/05/2011
update dm800 dm800se dm500hd dm8000 hardware drivers
- hotfix freeze after some channel changes
- throttled mpeg decoder debug output a bit
- fixed bcm4506 tuner crash (no hab ack messages in kernel debug)
- fixed bcm4506 manual LDPC FEC modes
- fixed readback of current pilot state for dvb-s2 frontends (needs a linuxtv api fix)
- readback corrected symbolrate and frequency for bcm4501 and bcm4506
- cxd1981 DVB-C optimizations
[HR][/HR] 21-08-2011
dreambox-dvb-modules: update dm8000 hardware drivers
- added 3D framebuffer support (for side by side and top and bottom 3D services)
(no auto detection yet)
- fixed audio sync problems on playback to live transition
- bcm4505/06
* experimentally added blindscan support (needs e2 changes)
* experimentally added "Turbo FEC" support (needs e2 changes)
* added constellation buffer read support
* fixed problems when more than one 4505/4506 tuner is used in the same box
* fixed standby problems
* added possibility to use SCPC optimized search ranges
- alps-bsbe1-c01a
* fixed locking problems (better performance)
- bcm4501:
- cxd1981: fixed tuner problems after bootup from deepstandby in DVB-C mode
- added Nagra rev. 1.1 CI support to dm8000
- small alsa signed / unsigned fix
Lastest Drivers for DM 8000 03.02.2012
update dreambox hardware drivers - cxd1981(hybrid DVB-C/-T) increased max. frequency to 900Mhz - cxd1981(hybrid DVB-T) fixed ineffective 5V for active antennas after mode change - bcm4505/6 improved receiption sensitivity (fixes problems with small dishes since blindscan support) dm500hd,dm800se,dm7020hd: fixed audio volume boost on alsa playback dm7020hd:
Drivers 02/02/2012 in tar.bz2 format
http://www.2shared.com/file/Pij9y321/dreambox-dvb-modules-dm8000-26.html
Agent X
- fixed strange aliasing noise on PCM Playback with needed upsampling
- finally fixed hybrid DVB-C/-T Tuner 5V output for active antennas
- don't fallback to DVI when the HDMI EDID was not readable
(this fixes some HDMI audio/video problems)
dreambox-dvb-modules_2.6.18-7.4-dm8000-20120209-r0_dm8000.rar (2.44MB)
dreambox-dvb-modules-dbg_2.6.18-7.4-dm8000-20120209-r0_dm8000.rar (902B)
dreambox-dvb-modules-dev_2.6.18-7.4-dm8000-20120209-r0_dm8000.rar (869B)
Agent X
Drivers DM 8000 HD OE 1.6 16.02.12
update dm500hd, dm800se, dm8000, dm7020hd and dm800 hardware drivers
- fixed overflow on aspect ratio calculation
 this fixes possible wrong scaled content
 - fixed scale factor calculation for dm800
 i.e. fixes wrong scaled IPTV services
 - fixed non transparent framebuffer after bootup
 this fixes not visible bootlogo before e2 starts on dm800
Update: OE2 Driver
update dreambox hardware drivers:
- fixed DVB-T with tda1004x based NIM
- fixed HDMI/DVI mode detection bug
http://uploading.com/files/f9965eae/dreambox-dvb-modules_3.2-dm8000-20120518-r7.0_dm8000.rar/
New Driver (OE1.6) dm 8000
[HR][/HR]
Update Driver 3.2.3
-dreambox-dvb-modules: update OE1.6 dreambox hw drivers
- fixed not working "dm7020hd" remote control with dm800se and dm500hd after fp update
- fixed demux bug
- small CI fix
Latest OE2.0 Driver Dreambox DM8000 (15/03/2014)
- revert tuner drivers to 20131228
****-bsp/dm8000/recipes/dreambox/dreambox-dvb-modules_3.2-dm8000-20140313.bb [deleted file] blob | history
****-bsp/dm8000/recipes/dreambox/dreambox-dvb-modules_3.2-dm8000-20140314.bb [new file with mode: 0644]
