Merlin-3 OE-2.0 Images DM7020HDv2
- Fix picon display in oled for dm800seV2
- Picon renderer: Add /data to path
- PiconLoader: Use data partition on 7020hd and V2 boxes
- PiconLoader: Adjust PathSelection Screen
- Update german translation
- ChannelSelection and MerlinEPGCenter: Use data partition for Picons on 7020hd and V2 boxes
- Initial checkin of ClockToText converter localization
-- output for shortDay (%a), fullDay (%A), shortMonth (%b) and fullMonth (%B) are translated via enigma2 locale now
- Update default skin: see -> Default-HD-grey-ME
Merlin-3_OE-2.0-dm7020hdV2-20130803
Gogi22
Merlin-3_OE-2.0-dm7020hdV2-20130816
Auf dem Feed liegen Updates bereit.
Merlin3:
- Merge UptimeInfo Converter to BoxInfo converter and add 6 new types:
BoxType, LoadAverage, MemInfo, FreeFlash, TempSensor (S0), Uptime. This
makes UptimeInfo converter obsolete
- reworked PiconMapper. PiconMapper is not using PiconLoader by adding a
virtual PiconSet. PiconMapper must be activated in Merlin Settings
and sref2name must be installed (available in Merlin AddonManager)
- Update polish locale - thanks to kosmacz
- Merge ServiceNameOrbital to ServiceName Converter and add two new
types: NameOrbital and Orbital. This makes ServiceNameOrbital converter
obsolete
Siehe auch: -> OE, Enigma2 und Enigma2-Plugins auf Schwerkraft
Merlin-3_OE-2.0-dm7020hdV2-20130816.nfi
Gogi22
Merlin3:
- PiconLoader: fix crash when PiconMapper is not activated
- WebIf: disable webifpastebin patch as reichi added something similar
- add missing translations to German / French
- PiconMapper: allow the do mapping by selecting a bouquet
Merlin-3_OE-2.0-dm7020hdV2-20130825.nfi
2013-Oct-04
Merlin3:
- remove obsolete Converter
- PiconLoader: display a Picon when only Partnerbox services exist (only working for Hotbird, Astra, Astra2)
- ChannelSelection: enable Picon update for Partnerbox
-services (when no PiconMapper is used)
- PiconLoader: clean up
- removed bitratecalc.so from merlininfo
-package, set a depends instead to enigma2
-plugin-extensions-bitrateviewer -- set new import to eBitrateCalculator in plugin.py
- PiconLoader: Try to get Picons for Partnerbox
-services without mapping (Astra, Hotbird and Astra2 only)
- ChannelSelection: fix possible crash when updating Picons (should only happen with PiconSets installed before the last update of PiconLoader/PiconMapper)
- enhance PiconMapper to support up to three PiconMapperSets. Please delete existing PiconMapperSets before using.
- DreamCC: fix crash Siehe auch: -> OE, Enigma2 und Enigma2-Plugins auf Schwerkraft
Merlin-3_OE-2.0-dm7020hdv2-20131117
Merlin3:
- removed shaderman's "rename entry" function from merlin source code, because DMM merged this code to their sources
- SkinSettings: new option to disable menu icons
- Updated German and French translations for new option; fixed typo in French translation
- ChannelSelection: (hopefully) last fix for oldPath initialize
Merlin-3_OE-2.0-dm7020hdV2-20131117.nfi
Merlin-3_OE-2.0-dm7020hdv2-20131201
Merlin3:
- simplified PiconLoader: removed virtual PiconSet for PiconMapper (using regular DVB-S PiconSets now). Please delete existing PiconMapperSet!
- reduced offered directories to those matching the size of the Picon when installing a new PiconSet
- simplified PiconMapper config: it's only required to activate the PiconMapper. Sets and directory no longer need to be selected
Merlin-3_OE-2.0-dm7020hdV2-20131201.nfi
Merlin3:
- german locale typo fix (thanks to chickatix)
- MerlinWebIf: fix Wiki-URL; hide not working menu entries for feeds; add feeds for dm7080
- update piconmappersets
Merlin-3_OE-2.0-dm7020hdV2-20141021 - DOWNLOAD
Merlin3:
- MerlinWebInterface:
-- remove outdated AV settings
-- add new AV settings
- PiconCleaner: don't crash when no picon is in list
- PiconCleaner: don't show picons as outdated when alternative services are used
- PiconLoader: fix issue when alternative services are used
- PiconMapper: fix crash on empty search string
- allow to toggle betweenn HD and SD during mapping (fix for some cable networks)
Merlin-3_OE-2.0-dm7020hdV2-20141109.nfi
