OE 2.0 Adons& Plugins
""Linuxsat-Support-Addons Plugin"
Addon's Installer from linuxsat-support
We are aware that many of you can no longer access our addon's server on TSpanel as the plugin is causing problems with the device manager in your images.
We can now offer you an alternative so you can once more use our addon's server again on OpenPLI based images, LinuxsatSupportAddons is a lightweight plugin where you can install the latest softcam packs, settings, picons etc. It will not overwrite any system files on your image so you can install safe in the knowledge it will not cause any problems with your image.
Installation
Available for OE 1.6 2.0/3.0 images
For OE 1.6 based images
Choose the file ending mipsel.ipk, ftp the file to /tmp then install manually from your images addon manager.
