OpenDreamy.by.mmark
bica
10.09.2011
1.128
1.745
OpenDreamy v1.1 1920x1080 FHD
Minor Fix
Add Support for openLD Image
Add Support for openRSI Image
30/09/2016 FIX MediaPlayer Crash
OpenDreamy FHD 1920x1080 v1.1
download
One Skin More Images
This skin is a unique project that supports many images of different teams can be customized with the logo of the various teams.
Reported bugs, missing panels, incomplete or incorrect panels, reported pli-based images to be included in the supported images.
Actual Support
Egami - ItalySat - Atemio4you - HDMU(*) - PKT(*)
OpenATV - OpenPli - OpenVix - OpenMips - OpenRSI
OpenNFR - OpenHDF - OpenDroid - OpenESI - OpenLD
Note for HDMU Images
The HDMU team, previleges reading its owners panels, directly, than detect them by the current skin. To display panels by opendreamy, you must delete or rename the file:
/usr/lib/enigma2/python/Plugins/Extensions/HDMUCenter
/skin/skin.xml and skinfhd.xml
30/09/2016 FIX HDMU Center/Info System Crash
download
Note for PKT Images
The owner panel of the PKT image, don't support the resolution 1920x1080
To properly display panels on FullHD, you must use this FIX.
The Fix don't change any original function of the panel, but makes it compatible with the skin fullhd.
Fix PKT
