OpenPli 4.0 dm8000
Siki78
13.09.2012
456
422
Sr.Kamenica
Uradjen je nova verzija OpenPli 4.0 za dm8000 jos uvek je test verzija pa pre nego sto uradite flash
napravite backup svog starog image.Update sa 3.0 nije moguc samo nova instalacija!!!
Pozdrav Siki
Direkt Download Link se obnavlja Update svaki dan i uvijek su novi image dostupni za download !!
Nije vise potrebno postavljanje istih!!!
~Download~Dm8000~
Poslednja izmena od urednika:
Reactions: 1 person
30.12.2012
6.825
4.552
crosatelite.com
OPENPLI
Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
A quick rebuild because we got a report that bug: https://bugzilla.gno...g.cgi?id=758928
was fixed by this commit: http://cgit.freedesk...29936f8b963e24b
Please test these two streams if possible and report back:
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3A//xg5tbqm52h1pot9.babahhcdn.com/witch/season1/304680.mp4:Dougnut test
#DESCRIPTION Dougnut test
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//cdn.phoenix.intergi.com/19850/videos/4357110/video-sd.mp4:Test MP4
#DESCRIPTION Test MP4
Hopefully the bug that prevents playing mp4 files from remote locations is now fixed :)
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1, no changes or extra patches added.
Only patch I've removed is: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch,
because that patch is already accepted and commited to upstream git.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by Christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support
- Spark images includes the pti.ko from OpenATV so softcam's should work now.
- DM800 kernel will now always pass the vermagic check when loading modules.
Now you can try and load any DM800 2.6.18 kernel module from OE1.5 to 2.0.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
- On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
Because sometimes it doesn't scale back to fullscreen.
I've included the MX-HQ7 skin for use as workaround.
- On Zgemma Star you cannot use fullHD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
