Oscam for Qbox HD
veha
>>>> root <<<<
Oscam-svn-5097 for QBoxHD and mini LED ON DEFAULT
changed the parameter : disableqboxhdled = 0 (default)
added changelog version 5069 to 5097
http://turboupload.com/qsgphsnb94a3
Pazarac
oscam-svn7944-sh4-qboxhd-webif-Distribution
Changeset [7944] by theparasol
Add more log to set parity, could be usefull for [COLOR=#0033FF !important]tickets[/COLOR] like 2974
Changeset 7943
Author:theparasol
Message:
Removed the for [COLOR=#0033FF !important]display[/COLOR] only used ecm->checksum calculation and replaced it by MD5 hash
Changeset [7942] by gf
Make it easier to parse help output and learn the default config dir.
Pazarac
Changeset [7951] by lattjo
csctapi: Fixed MP35 reader init failed after reboot
Code:
Changeset 7950:theparasolMessage:Experimental:Removed the caid / betatunnel check on cacheanswers.Since the cacheanswer is only valid for a very short time I thinkfor cacheanswers we can rely on csp-hash and MD5 hash checksum of the ecm.If they match the ecm must be the same even if caid is different.</pre>
Changeset [8658] by theparasol
- More fix for radegast protocol tnx goodsat for patch
Changeset 8657
Author:theparasol
Message:
Fix for connection timeout after EMM is send over cs378x
Tnx to skyjet for patch
Changeset 8656
Author:theparasol
Message:
Revert 8655 (loadbalancer knocking failed srvids on readers once)
Add new parameter in reader setup lb_whitelist_service
tnx to Blueven for providing patch
Changeset 8655
Author:theparasol
Message:
Loadbalancer:
One fast retry of a srvid on a reader that failed before if no matching readers were found.
If srvid fails again failfactor*reopenseconds are enforced on further no matching reader situations.
Tnx to Blueven for providing additional patch, report issues in forum!
<!-- / message --><!-- attachments -->
Changeset [8667] by bowman
Fixed debug logging that wasn't platform independent
Changeset 8666
Author:bowman
Message:
Completed support for incoming udp cache updates from csp and added experimental outgoing push (untested)
Changeset 8665
Author:Eggy123
Message:
a) Fixed bug in hello logic: start counting card number at 0 again after hello packet send
b) Switch to next state only after last packet
thanks Gianni8127
thanks hapeba
Changeset 8680
Author:
theparasol
Message:
Added CA PMT Server support (PMT6: PIP on DM7025 reported to have issues)
Revised the ecm requesting and ecm response handling
EMM start and handling changed (now emm on expired cards and FTA channels)
Revised the handling of controlwords (using wrong index should not happen anymore)
Reopenonzap:
Some users report that VU+ boxes needs this checked otherwise issues after a timeout response
This patch is checked by many regular users of streamboard and considered trunk ready.
Changeset [8679] by Deas
adjust a few more text alignments in web-if
Changeset [8678] by Deas
fix some typo´s - see #3324. tnx to skyndas
Changeset [8677] by bowman
Allow for larger ping regs/replies (possible multics fix).
Changeset 8676
Author:bowman
Message:
Added csp cache peer ping times in webif (mode column). E.g: csp (12 ms). Will be shown for all csp cache peers with confirmed working bidirectional traffic.
Changeset [8675] by docman
Documentation update for 'ecmfmt': new option ONID.
Changeset [8674] by docman
Documentation update for CSP: TCP -> UDP.
Changeset [8673] by docman
Added new parameter 'lb_nfb_readers' to 'oscam.user', now TXT and HTML … etcetera
Changeset [8672] by docman
Added new parameter 'lb_nfb_readers' to 'oscam.user'.
Changeset [8671] by docman
Documentation update for gbox port definitions.
Changeset [8670] by manio
cosmetics: fix MHz spelling Hertz is a unit from SI and need to preserve … etc
Changeset 8691
Author:
theparasol
Message:
Fixed a typo in lastemm for irdeto cas (1 hour = 3600 sec)
PMT6 mode doesnt use camd.socket so why start it (!)
Changeset 8690
Author:
theparasol
Message:
dvbapi overhaul update:
Fixes for irdeto cas handling (tnx Gismo2004 for testing and reporting)
Before ecm is requested we check again if there still is a matching reader
Fixes for dm500 ppcold (cant do section filtering / no correct return on ioctls)
No more attemps to start descrambling on FTA channels
Local irdeto cards need a valid emm update in last 60 minutes before ecms are asked
On failing irdeto ecmpid disable emm filters for it (requested by Bruty)
Changeset [8689] by bowman
Fixed typo.
Changeset [8688] by bowman
Fixed copy/pasted webif template name for reforward setting in r8685.
thanks Gianni8127
