Oscam Raspberry
Misik
imate možda najnoviji oscam za Raspberry ili gda ga mogu skinuti
zadnja verzija koju imam je 11401
Ima novija,i molim da se u upload sekciji ne diskutira.Ima posebna sekcija za diskuziju!
/ _ \/ | / _| _ _ __ ___
| | | \___ \| | / _ | '_ _ \
| || |__) | || (| | | | | | |
\/|_/ \_\,|| || ||
| OSCam ver: 1.20_svn rev: 11439 target: arm-bcm2708-linux-gnueabi-ssl-libusb
| Tools:
| CROSS = /opt/s3/support/toolchains/rasb_soft/bin/arm-bcm2708-linux-gnueabi-
| CC = /opt/s3/support/toolchains/rasb_soft/bin/arm-bcm2708-linux-gnueabi-gcc
| Settings:
| CONF_DIR = /usr/local/etc
| CC_OPTS = -O0 -ggdb -pipe -ffunction-sections -fdata-sections -finline-functions -fno-short-enums -freg-struct-return
| CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition
| CFLAGS = -DWITH_SSL=1 -DWITH_LIBCRYPTO=1 -DWITH_LIBUSB=1 -DWITH_UTF8=1 -DWITH_UTF8
| LDFLAGS = -Wl,--gc-sections -DWITH_SSL=1 -DWITH_LIBCRYPTO=1 -DWITH_LIBUSB=1 -DWITH_UTF8=1 -DWITH_UTF8
| LIBS = -lssl -lcrypto -lusb-1.0 -lrt -lm -lpthread -ldl -lrt
| UseFlags = USE_SSL=1 USE_LIBCRYPTO=1 USE_LIBUSB=1 USE_UTF8=1
| Config:
| Addons : WEBIF WEBIF_LIVELOG WITH_SSL HAVE_DVBAPI READ_SDT_CHARSETS IRDETO_GUESSING CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX IPV6SUPPORT
| Protocols: CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE GBOX RADEGAST SCAM
| Readers : NAGRA NAGRA_MERLIN IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD DRE TONGFANG BULCRYPT GRIFFIN DGCRYPT
| CardRdrs : PHOENIX INTERNAL MP35 SMART
| Compiler : arm-bcm2708-linux-gnueabi-gcc (crosstool-NG linaro-1.13.1-2012.06-20120625) 4.7.1 20120531 (prerelease)
| Config : build/arm-bcm2708-linux-gnueabi-ssl-libusb/config.mak
| Binary : /opt/s3/support/binaries/oscam-svn11439-rasb_soft-webif-dvbapi-ssl-libusb-ipv6
