R-Wipe & Clean 20.0 Build 2292
BaDshaH
7.957
RWP
R-Wipe & Clean 20.0 Build 2292 | File size: 23.77 MB
R-Wipe & Clean is a complete R-Tools solution to wipe useless files and maintain your computer privacy. It irretrievably deletes private records of your online and off-line activities, such as temporary Internet files, history, cookies, autocomplete forms and passwords, swap files, recently opened documents lists, Explorer MRU (most recently used) lists, temporary files, and traces from more than 300 third-party applications, thus freeing up your disk space.
The utility wipes files and unused disk space using either fast or secure-erase algorithms. All files and folders may be entered in wipe lists to erase them in a single procedure. Supports both the FAT and NTFS file systems. You can combine separate wiping and cleaning tasks and launch them to begin erasing immediately or set them to begin erasing procedures as a background task at predefined times or events.
New R-Wipe & Clean supports Windows 10, 8.1, and 8, removes traces from more than 600 third-party applications, including Microsoft Office 2016 and Skype(!), and supports all recent versions of Microsoft Edge, Internet Explorer, Mozilla/Mozilla Firefox, Opera, Safari, Flock, Netscape, AOL, MSN, Google Chrome, SeaMonkey, BT Yahoo!, Konqueror, and K-Meleon, as well as the Google, Windows Live, Yahoo!, and MSN toolbars.
Features:
- The following items are added to the Internet (Skype) tab: Business Intelligence Statistics, Emoticons Cache, Internal Database, Media Transfer Cache, Stored Emoticons Information, Stored File Transfer Information, Stored Media Transfer Information.
- A new item Update Logs is added to the Microsoft OneDrive tab in the Application Traces section.
- The Typed URLs item is added to the Internet (Microsoft Edge) section.
- Three new items are added to the System section: Component-Based Servicing Log, Deployment Image Service and Management Log, Startup File Renaming Log.
- Four new items are added to the Setup Logs tab: Delta Package Expander Setup Log Files, Driver Package Installer Logs, Local Security Authority Setup Log Files, Setup Cleanup Task Log Files.
- The Swap file can be wiped and cleaned for Metro/Universal applications.
- Full support for Windows 10 and Microsoft Edge browser.
- 2 new items are added to the Internet (Google Chrome) section: Web Applications File System's Files and Google Cloud Messaging Traces.
- 7 new items are added to the Program Data section: Windows Defender Activity Logs, Windows Defender Detection Logs, Windows Defender Network Inspection Service Log, Windows Defender Scan Results, Windows Defender Quick Scan Results, Windows Defender Scan Logs, Windows Defender WPP Files.
- iCloud is added to the Application Traces section.
Whats New
http://forum.r-tt.com/r-wipe-clean-version-history-t8141.html
HOMEPAGE
https://www.r-wipe.com/
Download From Rapidgator
http://rapidgator.net/file/60bc9b6f339c98c199e659521d9de353/BaDshaHR-Wipe.Clean.20.0.2292.rar.html
Download From Nitroflare
http://nitroflare.com/view/B69B258E6C0320E/BaDshaHR-Wipe.Clean.20.0.2292.rar
