Samy i Jtag
21.02.2009
11.931
14.321
Sevnica-Slovenia
Owner Samsung DSR 9500
If you have visited this section of our forum means you are happy
Owner Samsung DSR 9500.
There are some versions of a given receiver,
Depending on marks and established FW it provides viewing
The coded channels using various codings.
DSR 9500EM VIA : 2 Smart Card Readers for Viaccess Embedded
DSR 9500VIA CI : 2 Smart Card Readers for Viaccess Embedded + 2CI Slots
DSR 9500AY: 2 Smart Card Readers for Viaccess,ConaxEmbedded + 2CI Slots
DSR 9500A EM VIA; 2 Smart Card Readers for Viaccess Embedded
DSR 9500AX 2 Smart Card Readers for Viaccess,ConaxEmbedded
DSR 9500AZ; 2 Smart Card Readers forConax Embedded + 2CI Slots
DSR 9500Z : 2 Smart Card Readers for Conax Embedded + 2CI Slots
DSR 9500AR : 2 Smart Card Readers for Irdeto Embedded + 2CI Slots
DSR 9500AT : 2 Smart Card Readers for Cryptoworks Embedded + 2 CI Slots
The most successful for the consumer as it is not strange, appeared earlier versions from this series it DSR 9500 EM VIA and DSR 9500 VIA CI (has advantage as is the opportunity to use modules CAM)
The most suitable variant FW For them 118 version of a software + EMU.
P.S. At present EMU on the basis of 118 software it is not supported any more. At the moment EMU it is based on 133 software, the founder has christened it as Sammy Revolution.
DSR 9500 A EM VIA at first sight differs nothing from DSR 9500 EM VIA but the ill-A letter And which costs after 9500 does not give an opportunity to fill EMU,
I shall not explain why as all the same at you it will turn out nothing, better at once refuse this invention.
The most optimum variant for this version to alter it in DSR 9500AY it will provide viewing the coded channels prophesying in Viaccess, Seca, Nagra, Betacrypt, Conax with use of cards proembroidered under Conax xin1.
To change the version in DSR 9500 A EM VIA it is possible only with help JTAG at presence full Dump
For versions DSR 9500 EM VIA and DSR 9500 VIA CI if they not patch for first time too it is required Jtag for change of the loader with 504; 505 on 500; 501 then it will be possible to change ï.î through COM port.
Under the following references you can download all necessary instructions, programs and files.
manual for loading FW
RS - 232
Connecting DSR9500 JTAG
download :
[URL=http://freestorage.ro/iyc251iu6sjc]Samy_i_jtag.rar - 2.0 Mb[/URL]
pass:adonis@crosatelite.com
