SoftCam Plugin 'EREN'
21.098
15.429
EREN plugin will help you decrypt channels using Viaccess,Seca,Nagra,CryptoWorks,Irdeto,BISS, CW, DCW keys.
also decrypting ECM with vModules but you must install (libeay32.dll, libssl32.dll)
files to WINDOWS\SYSTEM32 directory in order to use ECM decryption.
and (*.mdl modules files must be in 'vModules' folder of EREN directory)
12-12-2010 [the first release]
v0.1
- ECM filtering
- Auto ECM option.
- Integrating vModules of vPlug with plugin (*.mdl modules files must be in 'vModules' folder)
- EREN will be updated soon to use "Softcam.key" standard plugin key
- Decryption with DVB CORE, (not tested)
- Decryption with ProgDvb, AltDvb, DvbDream (Test OK)
- Biss, CW, DCW key from ini file;
* You can enter keys manually via Biss&Dcw interface.
* BISS -> 12 digits
CW -> 16 digits
DCW -> 32 digits
- Thank's goes for vahid and its helpfull XME plugin source and How to write/load vPlug's modules source.
- Thank's very much to +bsdocuments+ for its endless and persistent help.
Thx Crypto26
Reactions: 1 person
