Weather Plugin
Weather Plugin
Since it is not a CVS Images weather plugin is, I did my time such permits to implement.
They can be any number of places in the settings (press the menu listed in the weather-view) (either city or ZIP code to specify a language for example, can de will en, it, ru entered, etc.), the weather display can be then use the arrow left or right to navigate through this fast and comfortable and can display the data.
To find in the annex or enigma2-plugins to gravity.
Update: 14.09.2012
Universell installierbar in OE 1.6 und OE 2.0!
Universally installable in OE 1.6 and OE 2.0!
Version 2.9.7 changes:
• Use specified "Frame size in full view" value when showing "5 day forecast" chart
• Info screen reworked
• False temperature colors fixed
• Up/down keys now scroll by page in main screen (without highlighting selection)
• Unresolved: Crash when scrolling in help screen of city panel
Gruß
JuSt
Version 3.0.0 changes:
• Option added to select measurement units. Thanks to muca
• Option added to select time format.
• Setup menu reworked.
• Main screen navigation modified: Select previous/next day by left/right key
• Many Italian cities added and Italian localization updated. Thanks to mat8861
• Czech, Greek, French, Latvian, Dutch, Polish, Russian localization updated. Thanks to muca
Gruß
JuSt
Foreca Wetter Plugin
[TABLE]
[TR]
[TD="class: alt2"]
Version 3.0.5 changes:
• Weather maps of Czech Republic, Greece, Hungary, Latvia, Poland, Russia, Slovakia added
• Some Italian cities added
• Temperature Satellite video added
• List of German states and list of European countries sorted
• Control key assignment in slide show reworked to comply with Media Player standard
• Thumbnail folders compacted
• Localization updated
• Unused code removed, redundant code purged
• Code cosmetics
Gruß
JuSt
[/TD]
[/TR]
[/TABLE]
Thx JuSt
josip11
crosatelite umirovljenik
Version 3.0.7 changes:
• Turkish cities updated. Thanks to atsiz77
• Debug state noted in log file
Gruß
JuSt
